changing out tranny's
hey guy's. Ive got a 302, 79 f100 style side, right now i have a four speed bulldog transmission. Dont really care for the low gearing, I am wanting something more adequate for normal driving
What i would like to do is either, go with a 5 speed manual,(for gas mileage. or, change it to an automatic.
I was told by a gentleman that I could use a later model atomatic transmission with manual overdrive (i think he said the overdrive connected to the drive shaft), Im really not very knowledgable about transmissions,
Id like to burn a little rubber if the mood hit, but also have a good top end running gear...
if im not mistaking, a c4 would match up to my 302
what is your suggestions.
AOD=Automatic ,with overdrive, not the manual 3+1 , which is a 3 speed almost like a top loader 4 speed but 4th is overdrive.
The AOD is almost the same size as a c/4 as far as the space it uses.
I have a couple i got by trading one of the 3+1 tranys for, i plan to put one in my 73 f-100 later.
Another option is the M5OD-R1 tranny has 5 speeds and has hydraulic clutch, but you have to change a few more things like pedals, clutch plate
With the T-170 really felt much difference, and improved gas mileage and the better thing is that i used the same clutch plate the same bellhausing and the same fork of the old t-18 .
is the T-170 a manual 4 speed or 5 speed,
What year trucks are they found in ? and it should bolt up to my existing bell hausing ?
When i change transmissions, do i need to do anything to my rear end ? change gears, etc.
I have a Hurst 4 speed shifter now, do you think it would be compatable with the t-170,
thanks guys, really appreciate the comments and suggestions.
Ford Truck Manual Transmissions
In my case i chose the t-170 FT (code rts) because it has overdrive and the shifter is on the top
the donor was year 88 2wd .
in fact you can use the same bellhausing the same starter and the same cluth plate of the T-18 .
ocastari, the Hurst shifter I currently should work with the t-170, it is a 4 speed shifter, would their be anything else I should change out with transmission ?
my clutch and everything seems to be in good shape, I cant notice any slip and it shifts very easy.
thanks for the help
dmarsh
thanks for the help
dmarsh
the tranny toploaded has 4 speed but i thing is not over drive like t-170 although both trannys has the same size , you dont need nothing else only swap this .
have you not thought about the other option the M50DR1 .?
want to research how much i have to change, If the t170 will match up with all my current setup, i was thinking that for now it would be much easier to got that route,
what exactly has to be changed out with the MD50DR1... i know you have allready told me the clutch plate and pedals ( is that all? ).
and on the Hurst, i am refering only to the shifter, (like i said, I am an transmission idiot... ive fooled with them a bit, but not really enough to say I know anything about them....
But: I THINK I'M FIXING TO LEARN....lol
thanks for all the info.
F100Newbie
05-29-2007 02:02 PM
Corner Gas
05-26-2007 10:28 PM
Schmids4.9l
02-02-2006 10:09 PM
Scott_in_Canada
07-03-2003 04:39 PM
