460 gas mileage improvements - Ford Truck Enthusiasts Forums
Old 10-02-2012, 12:33 AM
jl429 jl429 is offline
jl429 is starting off with a positive reputation.
79 f-3504x4 460 nv4500 trans 4:10 gears 33-12.50-16.5 tires anybody getting anything above 9.1 mpg? changed holley 600cfm carb to holley 750 cfm carb. 8.6 mpg -600cfm to 9.1 mpg-750cfm with#72 jets stock cam performer 460 manifold dual exhaust. truck regularly pulls 16ft. horse trailer with horses. any tips besides 12 valve cummins engine swap?
Old 10-02-2012, 12:49 AM
vic_v8 vic_v8 is offline
vic_v8 is starting off with a positive reputation.
maybe try a skinnier tire? electric fan?
side note, did you swap in that NV4500 yourself?
Old 10-02-2012, 06:13 AM
77F150Jason 77F150Jason is offline
77F150Jason is starting off with a positive reputation.
A 460 is what it is. It's not really known for gas mileage. If you're going to pull alot, I would just buy a diesel truck if you want any better gas mileage. just my opinion.
Old 10-02-2012, 06:16 AM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
460s are just thirsty. I dont think you can do anything to get much better then 10 mpg
Old 10-02-2012, 09:13 AM
psquare7575's Avatar
psquare7575 psquare7575 is offline
psquare7575 is starting off with a positive reputation.
I saw no mention of headers, any head work, aluminum items for weigh savings, electric fan, different pullies, a different cam, etc.
Old 10-03-2012, 06:28 AM
psquare, you nailed that one. X2 on that!
Old 10-06-2012, 11:48 PM
A machinist friend and I did the swap with a nv4500 swap manual. The tranny is out of an early 90's GM 1 ton with 6:34 granny gear.We made an adapter plate from a piece of 1" plate since there are no adapter plate for the early tranny. We used a GM 4wd mainshaft and installed a GM input gear in the NP 205 so no adapters on the mainshaft. We cut the input shaft on the NP 435 and the NV4500, cut an index pin on one shaft and bored a hole in the otherand made sure the overall length was correct. We used a welding procedure where we preheated the input shaft and welded the shaft with 100,000 psi tensil strength wire. No problems with the input shaft after 5 years of use. We used the original Ford cluch plate. We used a GM tranny mount and had to do some alterations to the crossmember. We lengthened the front driveshaft and shortened the rear. We had to relocate the transfer case lever and cut a hole in the tranny cover. I didn't notice any increase in mileage but it made the truck go faster. Total cost including the tranny approximately $1300.
Old 10-07-2012, 08:59 AM
grandmas77f150's Avatar
grandmas77f150 grandmas77f150 is offline
grandmas77f150 is gaining momentum as a positive member of FTE.
I wish I got 9 MPG. I get 7 with my 351M
Old 10-07-2012, 03:45 PM
kobaltblue's Avatar
kobaltblue kobaltblue is offline
kobaltblue is gaining momentum as a positive member of FTE.
Change it to a 445ci
Old 10-07-2012, 04:58 PM
f250custom78's Avatar
f250custom78 f250custom78 is offline
f250custom78 is starting off with a positive reputation.
Hmmmm your best bet for better mileage with a 460 is to pull the truck with a horse
Old 10-07-2012, 07:15 PM
spikinfool05's Avatar
spikinfool05 spikinfool05 is offline
spikinfool05 is starting off with a positive reputation.
9 with a 460 is not bad at all.
Old 10-07-2012, 10:32 PM
Just curious. Do you have E10 fuel there? When we went to that locally, I noticed a 10-15% drop in fuel economy, in all my cars....
For the love of my 460 Dave145 1973 - 1979 F-100 & Larger F-Series Trucks 19 02-01-2017 03:11 PM
Carb for stock 460, 600 or 750? f100beatertruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 11-12-2014 06:16 PM
Is 750cfm too much for stock 460? 74 F350 SCS 1973 - 1979 F-100 & Larger F-Series Trucks 16 10-15-2012 09:53 PM
460/750 Holley, all stock bad combo? 78bigunns Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 17 06-27-2006 07:53 AM
Holley carb for 460 Thomsen Fuel Injection, Carburetion & Fuel System 3 03-27-2004 04:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
