1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
7.3 liter diesel
Old 10-01-2012, 11:42 PM
rokinfarmer's Avatar
rokinfarmer
rokinfarmer is offline
7.3 liter diesel
When i get on my 7.3 every once in a while it will kinda white smoke, it has 176,000 on it and doesn't black smoke a drop, what could be causing it?
Old 10-02-2012, 08:57 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Does it feel like it is missing while you see the white smoke?
White smoke is unburnt fuel. You could have a loose UVCH on one side. Check all the wires going over the VC to make sure no chaffing is going on. Could be injectors.
Old 10-02-2012, 09:13 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
black smoke is unburnt fuel in a diesel not white, white usually is coolant leak
Old 10-02-2012, 09:32 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
If he had a 6.0, yes...
Since this is a 7.3, you may have an injector that's headed south or your UVCH may be coming loose.
You may also need some new o-rings on your injector. Depending on how old it is, you may just replace the injector with a reman one from Clay: Riffraff Diesel: Stock Rebuilt Injectors
Old 10-02-2012, 09:43 AM
rokinfarmer
Its has plenty of get up and go power and has never smoked, how could i figure out which injector to replace? Or just replace all 8? I just rebuilt the hpop and put new o rings on lines and fuel housing, and what is the UVCH?
Old 10-02-2012, 10:14 AM
Texas Chain Ring's Avatar
Texas Chain Ring
Texas Chain Ring is offline
Scroll down to Buzz Test.
Powerstroke
Old 10-02-2012, 11:04 AM
SuperDutyScaler
i just read it but it doesnt tell us how to do the buzz test? my dad would like me to do this but i dont know how?
Old 10-02-2012, 11:53 AM
miller_feed
Black smoke is poorly burnt fuel, white smoke is unburnt fuel on our 7.3
Old 10-02-2012, 02:19 PM
Texas Chain Ring
Apparently you need a scan gauge that performs the buzz test. You can search on Youtube "7.3 injector buzz test" and get an idea of what's going to happen, what to look for, codes and whatnot.
Old 10-02-2012, 04:08 PM
Toreador_Diesel
Retired Mod
rokinfarmer, where in texas are you located?
Old 10-09-2012, 10:23 AM
rokinfarmer
And what can i do to stop it from black smoking?
rokinfarmer
Im in galveston
Old 10-09-2012, 11:02 AM
Toreador_Diesel
Retired Mod
If your truck can make it, I can meet you somewhere around FM 1960 or somehwere in Katy.
Always armed with an AE....
Old 10-14-2012, 10:41 AM
rokinfarmer
When my truck is just at an idle i smell raw diesel so what is causing that?
Old 10-14-2012, 10:47 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Raw diesel at the tailpipe, in the cab, or standing in front of the truck?
Quick Reply: 7.3 liter diesel
