Upfitter Switches - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Upfitter Switches
Old 10-01-2012, 11:34 PM
Drake430 Drake430 is offline
Drake430 is starting off with a positive reputation.
Upfitter Switches
Hey everyone, hows it going?
Well I sold my 06 F250, and am now in an 05 F250 which has the upfitter switches that are calling my name and wanting to be used.
I've already read up on wiring them, but was just curious to know what most of you used them for.
Personally I was thinking:
1) Off-Road Lights (Front)
2) Reverse Lights --> Would be nice for bonfires
3) ???
4) High Idle Mod
So lets hear it, what are yall doing with them?
Old 10-02-2012, 01:19 AM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Backup camera over-ride. My head unit will let me view the camera if it is on.
I still have 3 to use for other things
Sean
Old 10-02-2012, 09:03 AM
xmontex4's Avatar
xmontex4 xmontex4 is offline
xmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to allxmontex4 is a name known to all
Compressor for air horns . How did you do the camera override!? my head unit has the option for a camera and i am in the process of wiring my upfitters.
Old 10-02-2012, 09:25 AM
joe_r_dog joe_r_dog is offline
joe_r_dog is starting off with a positive reputation.
if u ever wanted to hook up a cb, you could use one for that. im in high school so id put a pa on it just to say stupid **** to people
Old 10-02-2012, 09:45 AM
xmontex4's Avatar
Quote:
I almost did that but realized i had no use for it after high school lol. My friend had a Taurus wagon with one that made noise like the ice cream man and he would drive down all the streets with it, and it was the funniest thing.
Old 10-02-2012, 03:05 PM
SOB Racing's Avatar
SOB Racing SOB Racing is offline
SOB Racing is starting off with a positive reputation.
1. 100+ yard visibility HID lamps
2. Aux. Cooling fan
3. Rear Lights
4. Air Comp.
Remember two are 10 amp and the others are 30 amp. Plan ahead.
Old 10-02-2012, 06:00 PM
Yahiko's Avatar
Quote:
What I did was tap into the line that tells the head unit that the truck is
in reverse and pull the small amount of power for the camera. To make the
override I used a diode to keep the power from the uplifter switch from back
feeding the system and just taped into the camera power.
What you have to do with the diode is place it between the camera feed
and them place the new power feed on the end away from the backup
power. It works like a one way valve
Backup +++++ (diode) Tap >>camera
You need to make sure that the diode is the right direction so that power
will flow from it to the camera and the tap. If you put power on that line
when it not in reverse you can have some funny things happen like.
Backup lights on, park aid beeping , review vies mirror not dimming
when it should and so on.
Sean
Old 02-21-2013, 09:33 AM
djarch23 djarch23 is offline
djarch23 is starting off with a positive reputation.
Please pardon my ignorance. Can you go into more details about the diode? I have a mirror display unit on a 2013 f-250. Can you describe things like which wires to use, do you strip or cut the video in wire or the reverse wire, where do you connect the upfitter wire?
Old 02-21-2013, 04:18 PM
Yahiko's Avatar
I am not up on your year and model.
One thing DON'T cut the video cable. You do and you can/will end up with a
bad image. The reason for the diode is to keep the power from going back to the
the other controlling device. How you add it is this way. Pick your splice point
in the backup light signal wire to the camera control you make the splice with the
diode on the side where the signal is coming from and pointed so it does not block
the signal. The aux turn on power is placed on the line after the diode so that it will
supply power when you want and the diode keeps you from back feeding the reverse
lights while your driving forward.
Sean
Old 02-21-2013, 05:23 PM
Yahiko,
Thank you for the information.
Can anyone tell me what the color of the backup light contol wire is on a 2011+ Super Duty? Where is the best place, in the cab, to find this wire away from the mirror?
Thank you for the help,
Doug
Old 02-21-2013, 05:44 PM
ahco4693's Avatar
ahco4693 ahco4693 is offline
ahco4693 is gaining momentum as a positive member of FTE.
Doug, There is another thread on here somewhere discussing this. The problem you have is that after 2010 model year they started telling the camera to come on via a electronic message from the onboard computer(instead of a simple power wire previous years.) I was able to do this on my 2010 with the mirror camera, but I was unable to do it on a friends 2009 with the Navigation screen or a 2011 with the mirror screen. After additional reading it sounds like the only option for making this work on your truck is a LockPick device. Sorry!!
Upfitter Switches jhogh91 1999 to 2016 Super Duty 6 12-09-2015 10:45 PM
Aux lights don't work hooked to upfitter switch grelch Electrical Systems/Wiring 5 09-22-2014 09:29 AM
Upfitter switches on the 2011 Nipperdog 6.7L Power Stroke Diesel 61 09-19-2014 12:25 AM
What is Hooked up to Your Upfitters? DCP 1999 to 2016 Super Duty 7 09-26-2013 10:28 AM
2009 f250, gas upfitter switches SAYERS 1999 to 2016 Super Duty 2 10-18-2011 04:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
