Hood Latch - 51-52 F1
I need some help. I am rassembling a '51 F1 after a tear-down for painting etc. My hood is from a '52 F1 so the safety latch is a little different than the '51. My problem is I cannot figure how it installs. It looks simple enough as to how it drops through the hood and latches, but it makes no sense as to how it mounts. My painter tool it off so i am not sure it it is missing sometheing, etc. Can anyone help?
Did you look through my pictures that I posted in your other thread? The only difference between a 51 and a 52 safety catch is that the bracket that holds the safety catch in the hood is spot welded to the hood. In 52, that same bracket is bolted to the hood. So, line up the holes in the bracket with the holes in the hood. Look at the pictures I posted in your other post again. It'll make sense.
Otherwise, everything else (hood latch bolt and spring, hood latch mechanism and safety catch hook) are the same.
Mine definitely bolts in. When it is removed the bottom "exterior" side of the hood (where the latch penetrates the hood itself) is clear. The mechanism is in several pieces as per the drawing shown in Panelman's post, and there are a couple of bolts in the hood itself that appear to connect to it, but are "we;ded" by rust. I will take the picture tomorrow and send it to you . Maybe it will help explain my situation.
MO51
12-10-2001 05:43 PM
