Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-01-2012, 02:06 PM
oldbmwrider oldbmwrider is offline
Garage is empty, add now
oldbmwrider is starting off with a positive reputation.
Heavy duty three speed Transmission synchonizer
I have a 3 spd heavy duty trans. in a 1958 mercury half ton. It drops out of third gear when I go over 50 miles /hour unless I hold down the shift lever. I believe I need a new synchonizer for 2nd and 3rd gear. The part # I have is an old ford #. The synchonizer assembly # is B8QH - 7124 A. Does anyone know where to find one and is there anything else that could be the problem. I have also replaced the input shaft bearing and the output shaft bearing. This improved the problem but it did not fix it. Don
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
