Carb Help
Old 09-30-2012, 09:38 PM
JamesRH's Avatar
JamesRH
JamesRH is offline
Carb Help
I picked up a 1959 F100 at auction a few weeks back. Getting it home, discovered the previous owner had stripped it, and started installing a '79 302 V8 Widndsor, minus all externals (alternator, solenoid, fan, carb, etc).
I checked and found out a Motorcraft 2150 should be fine, and grabbed one at the salvage yard (with exchange policy just in case).
The issue is, I cannot figure out what rebuild kit to grab for it. The ID on the tag is
D9TF-BTB-C9F15
If someone could send me in the right direction for a good decoder, or somewhere else on the carb besides the tag to better ID it, that would be fantastic.
Thanks,
James H
Old 10-01-2012, 05:07 PM
spurredon's Avatar
spurredon
spurredon is offline
It would seem that if you went to NAPA and asked for a rebuild kit for a 2150 you should be all set. You might try posting in the 73-79 forum! Enjoy your new truck!
Old 10-01-2012, 05:08 PM
JamesRH's Avatar
JamesRH
JamesRH is offline
Good call, I forget that I have a '79 engine, not a '59, and those questions are best sent elsewhere.
I actually just figured out the issue, the tag was scratched, and it was a D9TE-BTB, which made it easy to locate.
James
08TRDOFFROAD
01-16-2015 03:58 PM
68cabby
05-26-2013 11:59 PM
Hickfied
09-28-2011 05:32 PM
bnradams
10-18-2009 12:58 PM
Flogger
11-05-2002 10:48 PM
Quick Reply: Carb Help
