Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 09-30-2012, 09:38 PM
JamesRH JamesRH is offline
Garage is empty, add now
JamesRH is starting off with a positive reputation.
Carb Help
I picked up a 1959 F100 at auction a few weeks back. Getting it home, discovered the previous owner had stripped it, and started installing a '79 302 V8 Widndsor, minus all externals (alternator, solenoid, fan, carb, etc).
I checked and found out a Motorcraft 2150 should be fine, and grabbed one at the salvage yard (with exchange policy just in case).
The issue is, I cannot figure out what rebuild kit to grab for it. The ID on the tag is
D9TF-BTB-C9F15
If someone could send me in the right direction for a good decoder, or somewhere else on the carb besides the tag to better ID it, that would be fantastic.
Thanks,
James H
  #2 (permalink)
Old 10-01-2012, 05:07 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
It would seem that if you went to NAPA and asked for a rebuild kit for a 2150 you should be all set. You might try posting in the 73-79 forum! Enjoy your new truck!
  #3 (permalink)
Old 10-01-2012, 05:08 PM
Good call, I forget that I have a '79 engine, not a '59, and those questions are best sent elsewhere.
I actually just figured out the issue, the tag was scratched, and it was a D9TE-BTB, which made it easy to locate.
James
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
