6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Its a smoker.....???? Too much!!! and burning oil....
Old 09-30-2012, 08:54 PM
shoobear's Avatar
shoobear
shoobear is offline
I have a 2008 first gen 6.4l
SCT tuner,with exhaust. It does still have the EGR system
Last summer I had it in the shop and they did a complete new EGR system. Was loosing coolant after replacing loads of parts they finally did the head gasket. Put ARP head studs in it at that time.
So....lately the truck has been blowing smoke...looks to be black. At idle and on the skinny pedal there is a smoke screen! The tuner is set on towing. The truck is burning OIL. Coolant level looks good. Not sure what would cause the oil loss....
Any thoughts?????
Old 10-01-2012, 12:06 PM
hockman2's Avatar
hockman2
hockman2 is offline
Take the tuner out, hopefully your under 100k and have Ford fix it!! Im betting its 1 of 2. EGR cooler meltdown or down injector flooding motor with fuel..
Old 10-01-2012, 01:38 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
I'd look at injector issues possibly.
As said by Hockman. Run it on stock power and see.
Old 10-01-2012, 06:37 PM
shoobear's Avatar
shoobear
shoobear is offline
Truck is off waranty.
The DPF was taken off so if the stock tuner is removed it will go into regen within a few miles.
How is it possible to loose oil with a stuck injector?
I was thinking turbo....?
Old 10-01-2012, 07:02 PM
senix's Avatar
senix
senix is online now
i missed the burning oil part. Turbo sounds more like it
Old 10-01-2012, 08:48 PM
shoobear's Avatar
shoobear
shoobear is offline
pulled a few codes from my SCT tuner...
U0115
U0100
U0101
any links to find what these codes are?
Also pulled the intake boots off to the turbo on both sides and found BLACK and wet and looks like a bit of oil....
If it is the turbo what part of the turbo failing would cause this?
Old 10-02-2012, 04:55 AM
senix's Avatar
senix
senix is online now
U0101 is just a communication error. The others I do not know.
Old 10-02-2012, 06:30 PM
cheezit's Avatar
cheezit
cheezit is offline
all 3 are network faults. remove lower cac boot from cac check for excessive oil. check crankcase for over full level. remove down tube from back of turbo and check for oil in exhaust
Old 11-12-2012, 09:22 PM
shoobear's Avatar
shoobear
shoobear is offline
i think there is oil in the exhaust...there is a BLACK drip mark on the ground where my truck warms up every morning....
Old 11-12-2012, 11:57 PM
parkland's Avatar
parkland
parkland is offline
That could just be soot n water making a dark drip.
Old 11-13-2012, 05:02 AM
senix's Avatar
senix
senix is online now
x2 condensation. You have to check when warm.
Old 11-13-2012, 06:13 PM
parkland's Avatar
parkland
parkland is offline
what color exactly is the smoke out of the exhaust during idle, and during driving?
msta999
02-27-2021 12:09 AM
KING
11-14-2013 07:33 AM
matty169
01-03-2011 07:56 PM
broncoformudv
01-03-2011 07:00 AM
Kula
12-27-2010 12:24 AM
Quick Reply: Its a smoker.....???? Too much!!! and burning oil....
