looking for 4.56 gears for D60 and Ford 10.5 F250 5.4
I cant find a site that has gears for both the front and rear diff on my truck.
I'm looking for 4.56 gears and mini install kits for my front D60 and my rear 10.5 both originally 3.73 gears
every site I go to has only front or rear gears. What sites do you guy's suggest?
Take a look at www.diffsonly.com. I used them when I purchased the Eaton TrueTrac and had no issues. I can't vouch for ring&pinion stuff as I kept my 3.73's. A quick look through their inventory for the D60 and 10.5" looks like they may have what you are looking for. Good luck.
You can edit the title... just hit edit on your first post, click "go advanced" and you can change it in the title box.
BroncoGraveyard has front and rear gears/kits:
Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale
I can find everything I need at multiple sites, I would like to get everything from one.
Ford 10.25" Yukon Ring and Pinion, 4.56
The Yukon website lists the same #24088 PN for the 10.25 and 10.5" for just the gears, call them and ask about what's different between kits PK F10.5-B/YK F10.5-B and PK F10.25/YK F10.25, and if the gears are the same other than just the install kits. The gears should be the same because long pinion 10.25" gears should bolt directly into your carrier.
http://www.yukongear.com/Contact.aspx
https://www.ford-trucks.com/forums/1...rear-axle.html
I believe that the kit below is what you are wanting... contact the vendor for confirmation.
D60 & 10.5" 4.56 Thick Gears + Master Bearing Kits
Item #722210 - New
1999-2008 Ford F250, F350 Superduty
2000-2005 Ford Excursion
(1) 4.56 Thick D60 Reverse Ring and Pinion
(1) 4.56 10.5" Ring and Pinion
(2) Master Bearing and Seal Kits
Timken Bearings
This kit includes a new ring and pinion for the Dana 60 and a new ring and pinion for the 10.5" rear and the master bearing and seal kits for both axles.
Our Price: $879.00
Item #722210 - New
Timken Bearings
Our Price: $879.00
Item #722210 - New
Timken Bearings
Our Price: $879.00
Item #722210 - New
Timken Bearings
Our Price: $879.00
Thank you.
Just for the hell of it I did some serching on summit. The only reasom I'm tring to avoid buying bearings is because the one's in my truck have less then 20k on them.
Anyway, this is what I'm looking at
G2 Axle & Gear 25-2034 - G2 Axle & Gear Standard Installation Kits
Motive Gear D60-456XF - Motive Gear Dana Ring and Pinions
Motive Gear F10-5-456PK - Motive Gear Ring and Pinion Sets
Ratech 121K - Ratech Standard Ring and Pinion Installation Kits
Am I missing anything?
Will this work in a 04 F250 5.4 V8?
Let me know.
Let me know.
