Project Ideas - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Project Ideas
Old 09-30-2012, 06:00 PM
1925mosin 1925mosin is offline
1925mosin is starting off with a positive reputation.
Project Ideas
Hello everybody.
Recently I picked a new daily driver (2002 Honda Civic Si) for commuting to work, so now I can store my 94 Lightning for the winter and will be able to do some more extensive mods. Already installed mods are full exhaust(Hooker long tubes, Bassani midpipes sans cats, and Flowmaster 40 series mufflers), Banks Transcommand, long traction bars, electric fans, air intake, and smog delete.
Eventually I want to do a stroker build with it, but I can't afford all that right now. Does anybody have any suggestions for good power adding mods that can be done without pulling the engine? Just kind of wanting a fairly easy winter project.
Thanks!
Old 09-30-2012, 06:42 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
NOX!!!!!!!!!
Old 10-02-2012, 12:04 AM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
Get it Dino tuned.
Old 10-17-2012, 11:22 AM
Luthier Luthier is offline
Luthier is starting off with a positive reputation.
Call Stiegemeier 636-949-2275 and get your blower done over and throw a 6lb. lower pulley on it. Pulley LFP 281-385-5339
Old 10-17-2012, 05:31 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Call Steig if you have a Cobra. Otherwise, it's an absolute total waste of money for Lightnings.
Stewart
Old 10-17-2012, 10:01 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
^Agreed, especially for a GEN 1.
What kind of budget do you have to work with and what kind of power are you after?
Old 10-19-2012, 11:29 PM
No clue what stewart and luthier are talking about. I don't have a blower and I don't intend on putting one on.
Eventually I'd like to push over 500 rwhp naturally aspirated, but thats several years down the road. And budget wise eventually i wouldnt mind dropping upwards of 10k in the drive train, but I don't have that kind of money right now or a place to take on a project like that.
As of right now I just kind of want something to do over the winter to add a little more to it. 1k would be my max for this winter since i just started a new job and i'm trying to get some sort of a budget worked out.
Old 10-21-2012, 12:44 AM
Blurry94's Avatar
Looks like you have the bolt-ons covered already. I'd definately suggest doing a roller cam swap then. You can use the roller hardware (spider, lifters, dogbones) from a 5.0 stang or mid/late 90's F-series pickup, and it's usually less than a 100 bucks. If your rig is still speed density then your cam choices are going to be a limited. A custom grind cam will take the guess work out of choosing an off-the-shelf cam, and it would be something you could sell later on when you plan on doing your next build.
What are you using/doing to tune your rig?
Old 10-21-2012, 06:14 PM
As of right now I don't have any tuning software whatsoever. As far as I know the computer is 100% stock. Is there a way to do a cam install without pulling the engine? I don't have a lift or much space in general to work.
Old 10-22-2012, 12:08 AM
Blurry94's Avatar
No need to pull the motor, however, you'll need to remove the radiator and possibly the A/C condenser. I'd also suggest installing an adjustable fuel pressure regulator to help increase the fuel pressure at WOT. Also, look into getting a wideband O2 to monitor your air/fuel ratios and it'll also help dial in your FPR.
Old 11-01-2012, 06:12 PM
Thanks! I think I'm going to look into getting a wideband o2 as well as some tuning software and what not. Any suggestions as to brands or what software/chips to use? I've heard Moates Quaterhorse is good, but I zero experience with tuning or any of the electrical stuff.
Old 11-03-2012, 12:25 PM
mortonhydraulics mortonhydraulics is offline
mortonhydraulics is starting off with a positive reputation.
cheap upgrade
i suggest that you go on ebay and get some ford 289 heads i got a set for 200 bucks, look up the different cubic cc's i found a set of e5ea but the same cc head is listed with several different part numbers.
Old 11-03-2012, 10:12 PM
Ironhand03 Ironhand03 is offline
Ironhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputation
Quote:
Quote:
Stewart
Steigemeier has horrible customer service and refuses to answer certain questions about products he sells. Even after one appears to have damaged a customers blower case.
LFP is a crappy business and rips off other peoples products left and right.
I can provide proof to these statements should anyone request it.
Old 11-14-2012, 03:06 PM
Longbed92 Longbed92 is offline
Longbed92 is starting off with a positive reputation.
I don't know if you done any transmission upgrades but I just put a Punisher Valve body in my 94 Lightning and it is awesome! Still comfortable to drive but it will chirp the tires on the 1st to 2nd shift. I'm really happy with it!
Old 11-19-2012, 05:18 AM
J York AL Tide J York AL Tide is offline
J York AL Tide is starting off with a positive reputation.
Before u modify. U should get a track time on it
400 Rebuild Round 2 HVACTOM 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 87 04-20-2016 09:29 PM
Fuel Tank Replacement granny_rocket 1994.5 - 1997 7.3L Power Stroke Diesel 7 01-26-2016 03:16 PM
Winter beater mods?? Krisx125 1994.5 - 1997 7.3L Power Stroke Diesel 3 01-04-2011 10:04 AM
3rd row captain chairs...??? gtmgooser Excursion - King of SUVs 11 11-28-2010 05:47 AM
89 bronco mods scbronco 1978 - 1996 Big Bronco 10 11-03-2006 03:11 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
