1948 F-1 Warner 4 speed pops out of 4th gear - Ford Truck Enthusiasts Forums
Old 09-30-2012, 03:10 PM
f1ford48 f1ford48 is offline
f1ford48 is starting off with a positive reputation.
I just rebuilt my 4 speed crash box with new bearings, shafts and thrust washers. the gears all had minimal wear so none were replaced. it is tight and smooth but pops out of fourth gear on long downhills-at slower speeds it eases itself out. at a higher speed [50-55] it poped out more violently- any advise on what to look for?
Old 09-30-2012, 08:47 PM
CHUCK48-50's Avatar
CHUCK48-50 CHUCK48-50 is offline
CHUCK48-50 has a good reputation on FTE.CHUCK48-50 has a good reputation on FTE.
Check the detent springs in the cover, and the cluster gear end play.
Chuck
Old 09-30-2012, 11:31 PM
Thanks Chuck- I will check the detent springs-I have the bullet shaped detent pins-do you know where I can locate the springs? Frank S.
Old 10-01-2012, 02:14 AM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
Popping out of gear can be a sign of a worn synchro gear. The gear teeth may look fine, but the synchro rings are what hold it in gear.
It could also be those detent ball/springs in the housing, but usually those aren't the culprit.
Dan
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Look on the bench where you did the rebuild.
That didn't actually help at all, did it? One in every crowd..
Sorry.
It's a ball/spring assembly, no? The spring would be behind the ball. It's been a while since I've been inside one. I had one with a cracked synchro that was hard to get out of that gear.
Old 10-01-2012, 02:19 PM
1948 F-1 warner 4 speed pops out of fourth gear
thanks to the next 2 guys but this is a SPUR GEAR 4 speed-no syncronizers.where do I find the detent springs for sale???
Old 10-01-2012, 02:24 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Quote:
Someone on here will probably have a parts transmission layin' around. I know of a good 'take out' but it is on the right coast and shipping would kill you. Till you find one, measure the hole the spring fits in and buy one at your local good hardware store. You'll probably have to cut the spring to fit. Buy a couple with different strengths and choose the one that works the best.
Old 10-01-2012, 07:37 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
Ford used that transmission starting in the Model A years. You can get every part for the transmission you need. Often it is easier to find four speed spur gear parts in the Model A parts supplier websites. I spent a couple minutes and found this: Sacramento Vintage Ford
An even better source is: http://www.vanpeltsales.com/FH_web/t...ruck4speed.htm
Old 10-02-2012, 12:02 AM
thanks-- I will check out vanpelt
3 on the tree 3rd gear problems the bird 1961 - 1966 F-100 & Larger F-Series Trucks 4 09-29-2010 12:40 PM
Transmission popping out of 1st IcutMetl 1987 - 1996 F150 & Larger F-Series Trucks 0 07-29-2010 11:50 AM
np435 1st and reverse question quaallen Clutch, Transmission, Differential, Axle & Transfer Case 7 04-12-2010 08:11 AM
Tranny probs camo1987f150 1987 - 1996 F150 & Larger F-Series Trucks 2 09-30-2009 08:53 AM
Third gear poping out HELP plzzz kona56 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-19-2008 08:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
