2.3 turbo - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
2.3 turbo
Old 09-30-2012, 03:04 PM
cpb2.3 cpb2.3 is offline
cpb2.3 is starting off with a positive reputation.
2.3 turbo
CB Performance Quick Tune EFI System. does anybody know what kind of performance. I would get with a set of dual downdraft 48mm throttle bodies and 25-30 psi boost? And has anybody thought of this?
Old 10-01-2012, 10:08 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Well for starters, what kind of supporting mods do you have on the motor to run that kind of boost? To run those kind of power levels, you really need a stand alone fuel management system, not a tuner. The truck will also be unusable on the street.
If you have done all the supporting modifications, you can deliver enough fuel, and the turbo is large enough, you should be hitting mid 600s. Problem is you can hit those kind of power levels with a single throttle body.
Performance parts for 2.3l? Nuetral Escape & Escape Hybrid 0 07-16-2010 02:12 AM
Gibson Cat-Back on '95 2.3L 95XL Ranger & B-Series 2 03-01-2008 12:33 PM
2.3 performance modifications? Great Parts 4 Cylinder Engines 3 01-28-2005 09:57 AM
Orfice tube location?? Traxxis Cooling, Heating, Ventilation & A/C 2 05-11-2004 09:25 PM
K&N High Performance Air Filter 94' Ranger Rc piston head Ranger & B-Series 7 07-09-2002 05:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
