Building a bad a$$ 6.0l - Ford Truck Enthusiasts Forums
Old 09-30-2012, 02:18 AM
FossenRacing's Avatar
FossenRacing FossenRacing is offline
FossenRacing is starting off with a positive reputation.
Have a 2003 f350 with egr delete, powermax turbo,updated oil cooler, blue spring, 6.4l banjo bolts, a early 100hp edge juice chip, slightly home ported exhaust manifolds, Arp studs and headgaskets, afe exhaust, has new to the truck injector also.
Truck runs alright, can take just about anybody in town. including the new 6.7l's
But i know my trucks got more. since the egr delete the truck has run with the egr fault underlying code(No MIL) the chip is a early gen and doesnt fix it.
I have no gauges which is stupid i know
and my spool time is terrible.
Have been looking at the banks big hoss bundle with the banks IQ
also a airdogII that replaces factory pump
and the ported intake manifold. Have shop in town that can possibly replicate it also.
I have no desire for custom tunes so bigger injectors are out.
If the trany cant handle it i will be buying a upgraded one with a banks torque converter.
any other mods i could do or is the banks hoss kit overrated?
Old 09-30-2012, 04:30 AM
Fulthrotl Fulthrotl is offline
Fulthrotl has a great reputation on FTE.Fulthrotl has a great reputation on FTE.Fulthrotl has a great reputation on FTE.Fulthrotl has a great reputation on FTE.
i pulled the banks IQ off mine.
i wouldn't recommend it, but if you are hell bent on an IQ,
i can make you a great deal on the one sitting in my garage.
most folks on here will suggest you run matt from gearheads
tunes.
i'd pass on the hoss kit.
Old 09-30-2012, 06:38 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
+1. Custom tunes are much better for the engine and the performance. Why rule them out? I know you have heard this, but ......... You aren't doing your tranny any favors with the Edge juice. Sounds like you are hammering it quite a bit also.
The PowerMax is a bit "laggy" without custom tunes, but then you know that now based on your post!
I do think gauges are a requirement if/when you mod the truck. Who knows what fuel pressure you are getting w/ the extra power.
As said above, you don't need all the air intake mods of the big hoss bundle.
Old 09-30-2012, 08:51 AM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is online now
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
I agree with Bismic, you need custom tunes. The Edge juice is not all that much power and the trans will suffer from it if you keep running with your current set up.
The stock air filter will handle 500HP so you could add a Spearco intercooler. Banks is no good for the 6.0L, only a name. You are on the right track replacing the stock fuel pump.
Old 09-30-2012, 12:52 PM
berick's Avatar
berick berick is offline
berick is gaining momentum as a positive member of FTE.
I had an Edge Juice with Attitude and I can tell you first hand that if you want more power, better throttle response and quicker/safer tranny shifts.... Go with the custom tunes from Gearheads. I had both so I'm not blowing smoke up anyones a$$. Myself, Matts SRL tune was fun but a lot more than what I needed. If you have headstuds and want a hotrod diesel than get their programmer with the SRL+ tune..… if you don't have studs, the regular SRL tune will still put a grin on your face and you won't be throwing away a tranny right away!
Old 09-30-2012, 01:24 PM
joe blow's Avatar
joe blow joe blow is offline
joe blow is gaining momentum as a positive member of FTE.joe blow is gaining momentum as a positive member of FTE.
Never used any edge products, I agree that BANKS is way overpriced and not the right choice for the 6.0L but I can attest to GEARHEAD custom tunes. Matt writes specific tunes for the powermax to reduce lag.
Old 09-30-2012, 02:20 PM
Crash16 Crash16 is offline
Crash16 is gaining momentum as a positive member of FTE.
Also a ficm tune might do you good to reduce turbo lag.
Changing from Banks to SCT tuner Sullid01 6.0L Power Stroke Diesel 5 10-07-2010 10:37 PM
6L build up Mach1 6.0L Power Stroke Diesel 2 04-08-2009 09:57 AM
SuperChips Powerstroke Microtuner vs. Diablo or Banks Big Hoss Chip hackatak 1999 - 2003 7.3L Power Stroke Diesel 10 05-15-2005 08:10 PM
Banks Big Hoss Stacking Question redrdr67 1999 - 2003 7.3L Power Stroke Diesel 11 01-17-2005 09:53 PM
Banks Big Hoss Bundle for 6.0L ?? waterskiers2 6.0L Power Stroke Diesel 3 09-05-2004 02:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
