Kickdown Linkage - Ford Truck Enthusiasts Forums
Kickdown Linkage
Old 09-30-2012, 12:42 AM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
Kickdown Linkage
Hey guys, I was wondering if somebody could give me a quick rundown on the purpose and function of the kickdown linkage on a C6 transmission. My old C6 had it, my new C6 did not. I still have half of the linkage from my old C6, and I'm wondering If I need to run the kickdown linkage with my 400, if they even came with kick down linkage.
Thanks!
Old 09-30-2012, 09:33 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
The linkage does what the name implies - kicks it down a gear with heavy throttle. You do not have to have that linkage, but you won't get the full-throttle downshift you'll want. The linkage was pretty standard and I have some if you want, but the carb has to have provisions for it. On an E'brock that's extra as they don't come that way unless requested.
Old 09-30-2012, 12:36 PM
I'll really have to think it over. Truth be told, I'll probably go without it for now, and if I end up wanting it, I can always add it later.
Thanks Gary!
Old 09-30-2012, 12:48 PM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I personally wouldn't try to run without it but I guess it's not absolutely critical, it just won't behave as well.
Old 09-30-2012, 01:11 PM
Gary Lewis's Avatar
When adjusted correctly the linkage only moves in the last little bit of throttle travel.
Old 09-30-2012, 01:47 PM
Biggest reason I ask is because I still have the transmission side of the linkage from my old 300/C6 setup.
But that linkage runs to the passenger side of the trans, since the intake on a 300 is on the passenger side, and that's where the carburetor sat. I'm not even sure if the linkage I have would work with a 400.
Need pic of 460/C6 kick down linkage Turbo Dog 1967 - 1972 F-100 & Larger F-Series Trucks 12 07-26-2014 09:20 PM
kickdown rod/ linkage dmar68137 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-19-2014 07:33 AM
linkage bushings abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 13 08-22-2013 11:33 AM
52' Ford w/302 and c6 kickdown linkage question? 52' fordnut 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-13-2013 06:44 AM
kickdown linkage jml72 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-29-2011 12:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
