460 coolant out of overflow - Ford Truck Enthusiasts Forums
Old 09-29-2012, 11:25 PM
Dodgehemi7's Avatar
Dodgehemi7 Dodgehemi7 is offline
Dodgehemi7 is starting off with a positive reputation.
I have a 95 f250 with a 460. I had coolant come out of the overflow bottle after sitting for a couple minutes. Has only happened one time but dont want to chance harming the engine. New water pump and thermostat 700 miles ago. Truck doesnt overheat. Drained oil to check for coolant, no coolant in oil. No oil in the radiator. Took radiator cap off and let run for about 25 minutes to get air out. Then replaced thermostat just to be safe along with letting it run with no cap on for about 25 minutes. I have pressure tested the coolant system and it held strong. Needle didnt drop at all. No leaks anywhere, and doesnt use coolant. Any Ideas ?? I am thinking maybe a head gasket but it doesnt leak, doesnt have white smoke, doesnt blow coolant out with the radiator cap off while idling. The only thing I am unsure of is, if the fan clutch works. Help before I tear in to replace the head gaskets.
Old 09-29-2012, 11:34 PM
Lead Head Lead Head is online now
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
I believe NAPA has a kit you can rent to test for combustion gasses in coolant to verify if it's a head gasket or not.
Old 09-29-2012, 11:36 PM
Dodgehemi7's Avatar
I didnt think of that. I will check tomorrow and see if they do. I am really hope that it is not a head gasket, it is getting old working on them more than you drive them
Old 09-30-2012, 10:41 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
try a new rad cap yet?
Old 09-30-2012, 11:32 AM
Dodgehemi7's Avatar
Havent replaced rad cap yet. But did test with the pressure tester and it blew off right at 13lbs like advertised. Heading down for combustion tester. Thanks for the help so far.
Old 09-30-2012, 12:21 PM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
The fan clutch may not be engaging when hot.
regards
rikard
Old 09-30-2012, 03:29 PM
Dodgehemi7's Avatar
I tried to get a combustion tester, didnt have one. Will try tomorrow. I think I am going to get a new fan clutch cause I am sure it is the original. By the way truck has 120,000 so I am sure it is in need of a new one anyway.
Old 09-30-2012, 04:09 PM
I have had two last over 150k and several that failed between 100k and 150k. Most of the Fords I replaced because the fan bearing was noisy, loose and/or not engaging. The GMs tended to lock up. Mopars were good but I haven't had a high mileage RWD Mopar.
I like electric fans but they fail too. The wife's Caprice has an electric fan and a fan clutch. I have installed electric fans as aux units to increase the performance of A/c units and transmission coolers in stop and go driving but would install two if I was eleminating the mechanical fan.
YMMV
rikard
Old 10-02-2012, 06:27 PM
Dodgehemi7's Avatar
Update:
Tested the coolant with a block tester (combustion fluid test). It passed and stayed blue in color.
Replaced the radiator cap to rule that out and am going to tomorrow for a new fan clutch.
After I replace those I will update but at this point I am going to rule out the head gasket and hope that I am right.
Thanks for all the help and will post after I get the clutch fan replaced.
Old 10-05-2012, 10:44 AM
Dodgehemi7's Avatar
Well I think I fixed my problem. Not sure what fixed it but havent had any trouble. Even while towing 5k didnt have any fluid come out or overheat.
Thanks again for the help
Old 10-11-2012, 11:48 PM
Dodgehemi7's Avatar
Update,
So about 150 miles now and have no coolant come out of the overflow. Not sure exactly what fixed my problem but seems to be doing great.
Will update if problem comes back.
Head Gasket woes? Old.Faithful 1973 - 1979 F-100 & Larger F-Series Trucks 24 05-30-2016 12:31 AM
1991 ford bronco 302 running hot Berardini2121 1978 - 1996 Big Bronco 8 04-23-2016 12:49 AM
Cooling system questions... (need some help) HooniverseJeff 1961 - 1966 F-100 & Larger F-Series Trucks 10 03-22-2015 01:13 PM
7.3 IDI - High Coolant Pressure and Leaking Head Gasket mytoys2037 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 06-18-2013 12:40 AM
Radiator Bubbles enikolich 1987 - 1996 F150 & Larger F-Series Trucks 3 06-17-2010 02:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
