Steering Linkage
Steering Linkage
I started having a little play in the streering recently and some new noises especially when backing out of the driveway with the wheels at full turn kind of a "clunk" "clunk"
Checking it out today and found some play at the column coupler maybe a strong 1/8" back and forth, is this the often refered to "rag joint"?
Also found some cracking on the front sway bar bushing so figure I will replace all of these.
Steering stabilizer shock also showing some wear hoping I can just get the shock and don't have to buy a whole kit? Anybody know if this would have been a factory setup (F350 Ranger XLT supercab camper special)
The rubber at the connection between center link and tie rod end is broken so I am guessing that means a new center link and tie rod end as well which will also take care of the pitman arm to center link joint. As a side note there is rotation of the whole linkage but no lateral or vertical movement in any joint if the steering is turned while i watch there does not seem to be any extra movement shoul dI replace all of this anyway?
this is the link to tie rod
this is the link to pitman arm
It also looks like the power steering is leaking from somewhere but have not tried to track it down.
okay I know Assuming I replace the sway bar bushings, center link, tie rod and stabilizer shock is there anything else that makes sense to change or check?
Thanks!!
Thanks!!
Thanks again
LiveFrom1977f150
19
06-12-2018 07:48 AM
inlandsurf
04-30-2008 08:45 PM
