I have a F250 with a heavy duty suspension, yes, even heavier than a F350, that was originally ordered from the factory in 1976. My question is, would it be better to put dual shocks on the front, or put on the sway bar? I have the add on bracket for the sway bar or additional shock. I even have the original setup for the back, for either the dual shock or sway bar brackets. I don't have a lot of body roll, even with a 11.5' truck camper in the bed. What do you think?
Is this truck a 2wd or 4wd ? If it's a High Boy then it must be aftermarket stuff because no sway bars or dual shocks were ever available from the factory for one.
