Please Help Me! - Ford Truck Enthusiasts Forums
Please Help Me!
Old 09-29-2012, 04:36 PM
Jake Mersing Jake Mersing is offline
Jake Mersing is starting off with a positive reputation.
Please Help Me!
1998 f250 LD 4x4 5.4l. I went to check my oil level today and notice that my battery was on its side and it leaked acid onto a whole bunch of stuff. most of the stuff wasn't hurt that bad just some melted wire loom covers and some paint taken off plus the oil fill cap was melted a little. But there is a blue and a pink little tubes that go from a plug on the top left of the firewall and go to something on the front differential but they totally melted through. What are these tubes and are they important.
Old 09-29-2012, 06:53 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
there are two small hoses that go to the axle pumkin area and connect to the vacuum piston. That engages the 4 x 4. The hoses start at solenoids on the firewall above the steering column, run to the right side of the truck and down the fender well area, then across the axle to the center pumkin area. One is engage, one is disengage.
Old 09-29-2012, 06:59 PM
yeah i figured that out now but thanks do you know where i can buy a new one?
Old 09-29-2012, 09:11 PM
steve(ill)'s Avatar
Might be able to buy a roll of plastic tubing at Auto Zone that is used to connect an oil pressure gauge to a remote mount. They should also sell 1/8 or 3/16 tubing for the end fittings. Maybe you can just replace a few feet of the failed part.
Old 09-30-2012, 01:36 PM
I kinda fixed the tubing but i still want to replace it. Do i have to worry about it getting locked in 4x4? How can i tell if its in 4x4? I'm kinda worried because i dont want to drive it if its locked in 4x4.
Old 09-30-2012, 07:22 PM
LilredWagon LilredWagon is offline
LilredWagon is starting off with a positive reputation.
As long as your switch on the dash is not in 4x4 H/L, you shouldn't have to worry about it getting locked in 4x4.
You'll notice a binding while turning on dry pavement if the truck is 4x4. Kind of like the truck is fighting you to turn. Very noticeable, you will definitely think something is wrong. Stop driving if possible and make sure switch is placed in 2H.
If it turns and drives like it normally does for you on dry pavement, then you aren't in 4x4.
Solvent Suggestions Sparky83 Garage & Workshop 11 07-21-2016 10:40 PM
A vacuum disaster Romancethestone 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-29-2015 08:32 PM
can't shift out of 1st - automatic C6 trans markeyd 1961 - 1966 F-100 & Larger F-Series Trucks 1 08-12-2015 08:18 PM
94 ranger 4.0 melts coil packs in seconds kunard333 Ranger & B-Series 18 08-25-2014 12:17 AM
DPFS melted... Psyclopse 1999 to 2016 Super Duty 11 02-15-2014 02:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
