1957 Ford F-250 found in Junkyard..What can I use???
Hey fellas,
I stumbled across a 1957 Ford F-250 in a local junk yard the other day, its a straight 6, 4 speed on the floor.
What can I use for my project 1954? I Already grabbed the door handles and the starter motor. Its exactly the same as the ones on my 54. The starter even works, and is somewhat hard to find after more research. This junkyard is really cheap, and all prices are set. (I got the starter for $17, door handles for $4 etc.)
I need about everything for my truck, including glass. Is any of that stuff the same? Bench seat? (any of you guys need anything for a '57?
Thanks guys!
Ryan
Thanks guys!
Ryan
6 cyl exhaust manifolds sell well and are hard to find in good condition. The temperature sending unit is specific for 56 and 57 fords only and Last I knew nobody was reproducing them.
57 hood emblems are desireable if they are in good cond as well.
I found 37 of these at a Ford Dealer in Exeter CA, sold them for 20 bucks each...and this occurred 1976/77. What would they be worth today?
1957/60 temp sending unit: B7A-10884-A (Motorcraft SW-363) / Obsolete ~ 56 available NOS / Also available from autoparts stores.
1954/64 223 trucks use the same exhaust manifold as 1954/64 223 cars, it's notorious for cracking. Very hard to find used in uncracked condition.
No Ford Dealer or obsolete parts vendor has any NOS, and the little charmer is not reproduced.
Ibuzzard bait: 6V positive ground thru 1955, 12V negative ground 1956 thru today.
Forest_54_Ford: 1957 Ford truck is an entirely new design, no body parts or glass interchanges with prior years. Outside door handles are 1957/60 only as are the window and door crank handles.
Powertrain might interchange...depending on years, but that's about it. 1957/60's have a hydraulic clutch. What Ford truck from day one thru the 1970's has a clutch cable? None.
