which heads with mercury crank
we are planning a rebuild of my EAB this winter. i'll be the owner/helper/gopher. i've got two good mech friends, one who has done flatheads. i have a mercury crank i'd love to put in it. i have one set of EAB heads (on it now) and a set of 8BA heads. the 8BA's were on my old engine that had the merc crank. is there any advantage with either set? do we need to worry about clearance? i think the 8BA and EAB's are both ford heads?? i do know that i need merc pistons for the merc crank and i believe the rods are the same ford/mercury?? thanks, trying to get my ducks lined up. dick r.
The EAB's are a little more preferable but the 8BA's will work ffine as well. The 8CN's are the early Merc 1949, into 1950. Then the 1CM's are the 1951 on and into the EAB's up to 1953.
Here in Canada the EAB's were used in the 1953-54 Flatheads.
Just be absolute that you use the Merc Pistons, they are just a little off from the 239 ones.
With more info and pictures
http://www.flatheadv8.org/clayhead.htm
EAB heads are the highest compression commonly available factory head for the late flathead Ford. Use them.
For more flathead compression ratio information than you know what to do with, get the pdf from here: Flathead V8 Compression Ratios...6,020 choices - The Ford Barn
