Apparently the 59A(B), 8BA, 8RT, and EAC heads all have the same 76cc size combustion chamber.
If I'm reading that right, 8CM heads also show the same combustion chamber size as those others, and that just can't be true. I believe this is more accurate, it's Joe Abbin's: Flathead Compression Ratio
