Starting trouble on 1951 ford f1 flathead V8
Old 09-30-2012, 05:21 PM
lvs2fly's Avatar
lvs2fly
lvs2fly is offline
Sorry for the delay responding...I had to take yesterday off and go watch the bulldogs take a bite out of TN...here's what I've got, I bought a new cable and ran the positive to the block, didn't change anything but I do feel better having it connected there. I have 6 volts across the dist. and batt post on the coil with the ignition switch on. I put a test light on the negative post and the dist. Side of the coil...it lights up, but when I open the points it stays lit. I tried to short the coil wire but nothing there. I've tried all this with the old coil and the new one. Do you think the coil is bad for sure? I appreciate everyone's help and look forward to your advice. Thanks!
Old 09-30-2012, 06:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Check continuity from the (-) post on the points (where wire and condenser connect) and the Dist or (-) post on the coil. I'd bet that wire is broken. Did you inspect it where it runs under the points plate?
Old 09-30-2012, 07:12 PM
WARDNEAL's Avatar
WARDNEAL
WARDNEAL is offline
If it stays lit on your test light with points open you have a short.
Old 09-30-2012, 07:17 PM
51M1's Avatar
51M1
51M1 is offline
Posted a video on how I test for spark with a screwdriver. If you have no spark, I 3rd the coil to distributor wire theory.
http://www.youtube.com/watch?v=qizoiVzUodY
Old 09-30-2012, 08:11 PM
lvs2fly's Avatar
lvs2fly
lvs2fly is offline
Thanks for the replies...the video was very helpful because I'm not getting that spark. Now checking for a short. Will let you know how it goes.
Old 10-03-2012, 08:09 PM
lvs2fly's Avatar
lvs2fly
lvs2fly is offline
Good news everybody! I found a short in the wire from the coil to the distributor, it was on the part inside the distributor. I now have SPARK!! My truck has been sitting since 1975 and the starter works (after a little persuasion from my hammer) and the coil is working. I did change out the plugs, plug wires, points, condenser, rotor and cap. I have no doubts that I can get it started now. I want to thank everybody that replied...without your help I'd still be scratching my head.
Old 10-03-2012, 08:26 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Good job Bud. Theses trucks really are not any more complicated than an old lawn mower I don't think. Really simple but most peeps today try to over complicate them. I guess that's why I can't work on my rigs today with the EFI electronic stuff. I just over simplify it and end up smoking a lot of stuff I don't even now the name of. There is just too many places on the newer rigs ya don't want to stick a screwdriver to see if ya got juice. All kinds of stuff lights up and smokes. Than ya sell it and some kid tows it off.
Good for you Bud.
Old 10-03-2012, 09:11 PM
51M1's Avatar
51M1
51M1 is offline
You're most welcome. Glad you got it figured out.
Old 10-03-2012, 09:36 PM
whitley's Avatar
whitley
whitley is offline
I had a similar problem with the little ground wire inside the distributor shorting out and overheating the coil. Glad you got it fixed!
MO-55F350
12-09-2009 06:26 PM
Lucky Charms
Electrical Systems/Wiring
36
01-07-2007 11:21 AM
Chris60F100
32
12-18-2004 07:05 PM
matt1960
11-01-2004 10:11 AM
hillbillyk
05-24-2001 10:18 PM
Quick Reply: Starting trouble on 1951 ford f1 flathead V8
