EBC Brakes - Who's Gottem?
So today I heard the faintest sound of metallic noise when applying my brakes. I was hoping to squeeze by this winter and change out pads and rotors in the spring but I am not that lucky.
I had switched to EBC pads on all my ATV's after a friend had told me about them and I was so impressed with them in that aspect that I thought I would research them a bit for my pickup.
Has anyone used these pads and rotors and are they noticeably better? They sell different colored pads and by the looks of it for a 1 ton that hauls a travel trailer every once and awhile in the summer, I figure the Yellowstuff pads look the best. Not too happy that they make a bit more dust than the stockers but I will take a little better braking if it means a bit more dust.
seat of the pants feel is double the braking power on a
10k# work van. and vans have smaller front brakes than trucks.
summit racing sells them.
Maybe it was the type of pads you were using? They have 5 or 6 different pads they sell for different applications.
Hmmm.... not what I was hoping to hear. I put the order in last night for new EBC Rotors and Yellowstuff pads. I got more than triple the life I got with my factory pads on my ATV and much better braking, so I figured automotive applications would be an upgrade as well. They seemed to get good reviews on the net.
X3 here as well
My MC Pads went 75K on the rear end and 85K on the Front end
Iv never had a After Market set come even close to that Half that would be luckey
just installed stock rotors and EBC's a couple months back
have just reached the break in mileage time to do the required 60mph-20mph E stops in order to transfer brake media to the rotors. When they were first installed they were very noisy for the first 100 miles or so but they haven't peeped a squeal since then.
These brakes shine under duress. Give 'em heat they love it. This is what they are made for.
When under normal braking there is no indication of a premium brake pad installed.
However under a load or in a panic stop they will put you through the windshield.
The green stuff or any other brake media will work just fine under normal circumstances and normal driving habits.
But this is what I was told from EBC: what the YellowStuff does best is... it is designed to progressively offer greater stopping power under duration and heat rather than fade.
So in summary, if you occasionally tow, anything you want to buy would work but if you want heavy tow brake pads, these are that kind of pad media you want.
I went with this pad media because of a bad experience I had when towing as I was headed West from Denver on I-70 outside the Eisenhower tunnel, very scary.
It was a tough trying to choose which pad to buy but I've always used this European made pad on my motorcycles. so I thought; why not the truck?
They also wanted to impress upon me that they will exhibit higher than normal brake dust but this is the trade off for this type of pad media.
I think Hawk also sell a heavy tow pad as well but chose EBC instead
When we take the truck and trailer out in the summer months, I always have to crank up the gain on the trailer brakes. I have had to stop hard a few times and it always feels as though the trucks factory brakes were straining..... this is the reason I went with the Yellowstuff pads. I realize they may leave a little more dust but at the end of the day I want the stopping power and I am hoping these accomplish just that.
stumpgc
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-29-2020 01:59 PM
