Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Old 09-28-2012, 01:12 PM
Leeet Leeet is offline
Leeet is starting off with a positive reputation.
Exclamation Broken front u-bolt bracket. Replacement?
I have a 99 F250 Super Duty 4x4. The u-bolt bracket on the front passenger side has rusted through and broken in two places. It has broken right at the hole for one of the u-bolts, which then broke the sway bar bracket off (so the sway bar is no longer attached on the passenger side). Also, the track bar bracket has broken off.
Is there a replacement bracket that can be purchased? Or does it need to be fabricated from scrap? The u-bolt bracket, sway bar bracket, and track bar bracket are all one whole piece. It is welded to the axle, so it would need to be cut off. Then the new bracket would need to be welded back on.
Thanks in advance for any help.
Here are some pictures:
Click the image to open in full size.
Old 09-28-2012, 07:41 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Holy rust batman.
The Motorcraft parts site lists it. Quite a few different parts are listed that are labeled the same so have the dealer pull up the diagrams and double check that the part is right.
Click on the photo in the links to see diagrams.
1999 Ford F-250 Super Duty Front Leaf Spring Axle U-Bolt Plate | FordParts.com
1999 Ford F-250 Super Duty Suspension Stabilizer Bar Mounting Bracket | FordParts.com
The Ford dealer should able to do a little better on the price.
__________________
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." (Thomas Jefferson)
Old 09-28-2012, 07:44 PM
Hotpocket's Avatar
Hotpocket Hotpocket is offline
Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.Hotpocket has a good reputation on FTE.
holy crap that truck is rotted
__________________
Alan
2004 F250 5.4 XLT FX4 3'' lift on 305s Diablosport tuned 270k +
Old 09-28-2012, 08:15 PM
mikeismadness's Avatar
mikeismadness mikeismadness is offline
mikeismadness has a good reputation on FTE.mikeismadness has a good reputation on FTE.mikeismadness has a good reputation on FTE.
That's fairly common for my area of NW Indiana. Usually Its the rear shackles
Old 09-28-2012, 08:25 PM
Hotpocket's Avatar
I can only imagine the bed supports cause my frame and everything else is rust free ..being a texas truck all its life but i do go to the beach alot and my supports are somewhat rotted
__________________
Alan
Old 11-15-2012, 11:35 AM
Mante's Avatar
Mante Mante is offline
Mante is starting off with a positive reputation.
http://facebook.com/​bernard.hill.jr
I've ran into the same problem, specifically the mount for the Track bar snapped off. I've had it welded back on with supportive gussets but in the event it happens again here are a few part #'s
3A093
Suspension Stabilizer Bar Drop Bracket
Monobeam (Front)
$115.17
5458
$112.20
5A316
Front Leaf Spring Seat Cap
4x4 and 4x2 Monobeam; 105mm between holes to mount stabilizer bar - LH (RH serviced with 3010)
$73.85
I have a screen shot but I can't figure out how to upload it..
Mante's Avatar
FordParts.com
Old 11-15-2012, 04:16 PM
SC_Hoaty's Avatar
SC_Hoaty SC_Hoaty is offline
SC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputation
Quote:
Same as any other picture. Use an image hosting site like photobucket. Upload the image to photobucket. View the image there, and find the code (on the lower right) that starts with [img]. Copy if from there and paste in in a post here.
If that's not clear, I can provide more detailed directions.
__________________
2009 F250 SC LB 5.4
2008 F250 RC LB 5.4
2005 F150 FX4 5.4
Old 11-15-2012, 07:50 PM
Mante's Avatar
Yea I figured that out, I posted the image right after that one. The linking of images is extra steps IMO, glad the fordparts page makes the image location available
Old Yesterday, 01:30 PM
Gnikhog Gnikhog is offline
Gnikhog is starting off with a positive reputation.
Front track bar/leaf spring bracket rusted/broken-need replacement
I also now have a badly rusted off/broken track bar bracket just like the original poster on the front of my 99 F-350 SD with stock suspension. This is definitely not a simple weld the bracket back on repair. I'm trying to avoid an axle replacement or bracket fabbed from scratch (limited budget).
Has anyone successfully purchased the replacement bracket/weldment from Ford or aftermarket? Alternative solutions are welcomed.
Similar Threads
Hood on 49 Ford F-1 1999 - 2003 7.3L Power Stroke Diesel 9 12-08-2011 11:02 PM
Changed spark plugs 5.4 3V @ 52k miles - pics D-Rock 2004 - 2008 F150 8 03-29-2011 08:55 PM
Broken off glow plug! mabc926 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 10-12-2010 05:03 PM
Update mabc926 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 05-06-2010 04:47 PM
Getting a spray-in liner & have a few questions d445 2009 - 2014 F150 73 09-04-2009 12:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
