1970 F100 Build Crown Vic Swap - Ford Truck Enthusiasts Forums
Old 09-28-2012, 09:18 AM
70f100bb 70f100bb is offline
70f100bb is starting off with a positive reputation.
Starting the restoration on my 1970 F100 SWB, putting an 04 Crown vic front suspension under it
Old 09-28-2012, 09:27 AM
Old 09-28-2012, 09:36 AM
Doner 04 crown vic for front suspension
here it is out and cleaned up a lil
front cap finally off
Old 09-28-2012, 09:50 AM
This is one way to lift the cab off lol
Old 09-28-2012, 03:35 PM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
Looking great! Mine is a '70 also. What are you doing for the rear suspension?
Old 09-28-2012, 05:03 PM
Undecided on the rear suspension right now, gonna stick with leafs, but I'm either gonna go with an explorer rear axle but then I gotta order custom backspaced rear wheels, if I use a certain wheel then I gotta find a 65" wide axle, then ill re drill the right bolt pattern in it to fit my wheels, I think an older f150 axle is close to that that I need
Old 09-29-2012, 05:57 AM
Got the motor and trans pulled out of the frame yesterday
started cutting out old crossmember and spring buckets
Got the new just setting under there, gonna be easier to install this then it was to remove all the old ****, took alot of cutting and air chiseling to get them old rivets out
Old 09-29-2012, 11:17 AM
Nighteyez's Avatar
Nighteyez Nighteyez is offline
FTE NorCal chapter LDR
Nighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputationNighteyez has a superb reputation
Excellent thread
Jim
Old 09-29-2012, 01:17 PM
elgemcdlf's Avatar
Quote:
Ain't that the truth! Drilling the mounting holes is fun though. You have the advantage of flipping the frame over which will make it easier.
Old 10-01-2012, 06:06 AM
made the spacers to bolt front end in
got it bolted in and the spacers tacked in, now gotta take it all back out to weld it up good and box the frame
Old 10-01-2012, 10:46 AM
Nighteyez's Avatar
Looks good so far. Boxing the frame is something I want to do to mine when I can get to it.
Jim
Old 10-01-2012, 01:36 PM
67-F100's Avatar
67-F100 67-F100 is offline
67-F100 is starting off with a positive reputation.
looks good! i wanna do CV front suspension on my 67, what year CV can i get it from?
Old 10-01-2012, 01:37 PM
elgemcdlf's Avatar
Quote:
'03-'11 are the years to look for
Old 10-27-2012, 03:26 AM
fixed body mount
rear mount of the lower control arms on
frame ready for sand blasting
Old 10-27-2012, 03:29 AM
got frame back from sand blasting, ready to get some work done on it
1961 F100 Crown Vic 4.6 Swap aka Franken Ford red05interceptor 1961 - 1966 F-100 & Larger F-Series Trucks 18 Yesterday 06:11 PM
Crown vic front end swap Carmax 1961 - 1966 F-100 & Larger F-Series Trucks 5 08-23-2016 01:49 PM
Crown vic rear Andy1966 1961 - 1966 F-100 & Larger F-Series Trucks 0 09-09-2014 10:04 PM
Weedin down Crown Vic wiring for install in a bumpside bumpsidep71 1967 - 1972 F-100 & Larger F-Series Trucks 13 10-16-2011 11:03 PM
1970 f100 frame gregfire 1967 - 1972 F-100 & Larger F-Series Trucks 8 11-20-2006 01:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
