Time to panic?
Time to panic?
I just started up my new 460 after many late nights of swapping it over after work and it ran great! BUT... white smoke. At first I wasn't concerned, I expected some smoke after handling all those parts and burning off paint, etc. But when the white smoke didn't quit after a little while, I shut it down. I stopped a couple of times to check the oil to make sure there was no water in it and it is fine. There is water dripping out of the tailpipe but I expected a little of that as well because my old engine blew a head gasket (I confirmed it with a compression test & water in the oil) and I thought there might still be some coolant in the exhaust system.
So, is it time to panic? Did I do something wrong? Is it safe to run it to see if it clears up? I was VERY careful when I installed the intake manifold because I've read about it being tricky.
Roll Tide
05-03-2010 12:37 PM
1985ColumbusF150
10-04-2004 12:09 PM
