cam phase timing ? Mike @ 5 star check this out
Guys my 2000 f-250 v-10 is sucking the gas literaly...only getting 125 miles on a tank of gas (29 gallon) this is with 10% ethanol chevron fuel. I was getting over 300 with non-ethanol when I could get it.
Any how...I have been chasing a couple of minor issues and seem to have them resolved, In the course of getting advise from a friend at my parts supplier...He recomended I call a friend of his who has a shop and does Diesel conversions and such and is knowledgable about the v-10's.
In the course of talking to the mechanic I mentioned about my gas mileage being half what it was, he told me he had a possible solution for that. When I pressed him on it he told me that he could hook up a laptop and adjust the cam phase timing(?) Has anybody heard of this? or is he blowing smoke?
Mike if you read this, I figure you would know if this would work or not? seeing as how you're the v-10 go to guy... BTW... I'm currently running tow -haul tune on my truck....thanks guys
I have heard horror stories about ethanol killing MPG, but that is
What's worse is, even if he thought the 3-valve V10 did, yours is a 2-valve.
So the guy is 100% wrong on both counts.
I would go back to the guy who recommended this "mechanic" and let them know they should stop recommending him to other people
The V10 doesn't have a cam phaser - only the 5.4L 3-valve does, and possibly the 4.6L 3-valver.
Thats what I thought as well. I have changed the fuel filter, changed air filter cleaned the maf as well. I pulled a plug..it was sorta white ashey(?) as soon as I have a good 1/2 day I'll change them out.BTW Im useing oem motor craft parts as well. I found some non ethanol fuel and have run a couple of tanks thru it ...i picked up maybe 20-25 miles per tank. I was gonna let the guy look at it to see if he can see anything obvious with it. this is after i took it by the dealership and the tech i know there hooked it to his diagnostics and could find nothing obvious.seeems funny that all the things i think it may be...IAC for example, they should throw a code if they are acting up, this truck has NEVER set a code in the 10 years i've had it. I'll keep ya'll posted, thanks
Britt, these motors don't throw codes for a lot of things. Especially the IAC.
Look through the tech folder ...
While it seems opposite of what you would think, a lean running V10 (according to your "ashey plug" comment) will get WORSE gas mileage. You might have a vacuum leak - check that PCV elbow at the throttle body.
I had to pull the hose to see the crack and it was pretty bad. I ordered mine and made a temporary while waiting for the OEM part to arrive. When it arrived I realized it was foolish to have replaced a known bad part with the same part. If I had it to do again I would have just skipped the OEM and kept my "temporary hose" because it did not have that sharp bend. Not to mention it was cheaper. I just used the correct diameter fuel hose about 18 inches long so it had a nice easy curve to it.
SuperDutyScaler
1999 to 2016 Super Duty
50
01-07-2013 12:17 AM
JasonVoliva
31
06-17-2011 01:21 PM
