Heated/Cooling Seat Light Blinking - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 09-27-2012, 09:22 PM
Loopy's Avatar
Loopy Loopy is offline
Loopy is starting off with a positive reputation.
The lights on the heated/cooling seat display blink when depressed on both the driver and passenger seats. Of course neither seat is working with this function. It's an 08 Expy El Limited btw.
Old 10-09-2012, 10:34 AM
Bopper's Avatar
Bopper Bopper is offline
Bopper is starting off with a positive reputation.
Just yesterday my seat heat/cool indicator lights would turn off immediately after they were depressed. I turned the car off and back on, all seemed to be corrected with the reboot. I have no idea what caused it, and I did not look at the manual. The blinking must be an error code of sorts, check the plugs under the seats.
Old 11-04-2014, 04:56 AM
Bopper's Avatar
I may have inadvertently fixed my heated seats with a battery change
In October of 2012 my seats began acting up. My passenger side heat would not work, the light would come on for about 10 seconds then would turn off and never come back. I have read all the online information that is out there, done all the free troubleshooting possible, including pulling fuses, changing filters, and figured that if I really wanted heat I would need to bite the bullet and head to the dealer to have my seats reprogrammed.
About 2 months ago I decided to change out the original 6 year old battery. I put in the biggest Motorcraft one I could find available for this car. The car was probably without a battery for about 1.5 hours. Long enough for any possible voltage to out of the cars system. After the install of the new battery the seats have been working as they should.
Last winter, the original battery had a few starts that where sluggish. After making it through the winter, i decided to change out the original battery prior to having a real failure. I am guessing the battery was weakened and had something to do with the seat heat issues. Maybe the seat computer was doing a self test prior to engine start and seeing a less then optimum voltage, and failing. Just a theory. I will repost if it fails again soon.
Old 11-17-2014, 05:31 AM
Bopper's Avatar
problem came back
After working for a month the passenger seat heat fails again after 20 seconds. Maybe I will disconnect the battery again to see if I can get another month out of it.
Old 02-10-2015, 09:06 PM
miekk miekk is offline
miekk is starting off with a positive reputation.
2003 EB heated/cooled seats quit working Welder7018 1997-2006 Expedition & Navigator 7 01-02-2017 02:18 PM
2012 f150 Fx4 3.5 eco heated/cool seat ? notastockdohc 2009 - 2014 F150 2 12-08-2016 07:31 AM
Heated/Cooled seats not working motoman67 1997-2006 Expedition & Navigator 9 11-10-2015 12:58 AM
Should I get a 2012 or 2013 F250??? Johnny Be Cool 6.7L Power Stroke Diesel 7 11-01-2015 10:06 PM
Heated and cooled seat has stopped working on my 07 Expy CarbonClear 2007 - 2014 Expedition & Navigator 28 10-08-2015 08:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
