Soft Brakes - Ford Truck Enthusiasts Forums
Soft Brakes
Old 09-27-2012, 08:50 PM
vtjvt's Avatar
vtjvt vtjvt is offline
vtjvt is starting off with a positive reputation.
Soft Brakes
Hey all, I have been reading and searching the forums and just need a little more info. My brakes are soft and sometimes go to the floor. I have checked front and rear, adjusted rear, bled brakes, and no change. When the truck is not running I have a nice hard pedal but as soon as I start it they go soft. If I pull the booster line with the engine running they firm up again. I am thinking Bad booster???
Old 09-27-2012, 09:08 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Sounds more like a bad master rather then booster, seams booster is doing as designed.
That said you have to check the rubber lines, make sure they don't bulge out under pressure.
Calipers original? Might be time for fresh set.
Test the master, solid plug both line ports and with the motor running is the pedal still soft/goes to floor?
If it does the problem is in the master, needs bleed or is bypassing pressure.
If the pedal isn't soft/doesn't go to the floor with ports solid blocked, you know the problem is down stream of the master.
Old 09-27-2012, 10:03 PM
vtjvt's Avatar
Thanks, I will do some more testing this weekend and post back the results
Old 09-29-2012, 07:34 PM
vtjvt's Avatar
OK, UPDATE!!!. It failed inspection. I put in a new master cylinder and now the brakes are back to normal. But the ****** that inspected it failed her for all 4 tie rod ends. I have an appointment monday with the dot so they can check them. They are all less then 30 days old.
Old 09-29-2012, 07:49 PM
Quote:
If they are less then 30 days old then why, what was the reason given for them failing?
Even the cheapest bottom shelf total crap tie rods ends sold, they wouldn't have notable play in them at 30 days after had been installed new.
Old 09-29-2012, 07:57 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
Tie rod ends? You have 2. I bet you failed for ball joints. You have 4 of those.
Old 09-29-2012, 08:05 PM
Quote:
There is a total of 4 tie rod ends in the steering linkage but have a feeling you might be right, ball joints as the reason for failing rather then tie rods.
Old 09-29-2012, 08:09 PM
Posting Legend
That's easy to check. jack up the truck until the tire just leaves the ground. Take a large bar, and set under the tire. Have a friend raise up and down on the bar while you watch the ball joints. You will see them move if bad.
If there are grease fittings in them, pump them up, sometimes that will tighten them enough to pass.
Old 09-30-2012, 02:12 PM
vtjvt's Avatar
No, ball joints are fine, It failed for all 4 tie rod ends. 2 inner and 2 outer. Main reason is that the guy is a IDIOT. His reason is because they pivot in the socket. No side to side or up and down play. just pivot. (kinda like they are designed to do) Oh well I have a opiontment monday with the state to have them check the truck and to file a complaint on the guy.
Old 09-30-2012, 02:50 PM
Yea that's crap, guy has no business inspecting vehicles.
Old 09-30-2012, 02:56 PM
Ole Blue (Pete) Ole Blue (Pete) is offline
Ole Blue (Pete) is starting off with a positive reputation.
What state is this??? Ridiculous inspection junk...
Old 09-30-2012, 05:06 PM
vtjvt's Avatar
Quote:
the state is Utah.
This guy has been in business for 16 years. I am hoping he won't make it to 17. He failed all 3 of the cars before me for really stupid crap. and even told one lady she would be ok driving with her car expired because she was pretty and the cops would let her go.
Another Soft/Fading Break Issue 70T351W 1994.5 - 1997 7.3L Power Stroke Diesel 33 11-21-2016 02:22 AM
F-150 Soft Brakes question fx4x4 Brakes, Steering, Suspension, Tires, & Wheels 1 07-26-2016 12:53 AM
Wooshing sound when you step on brakes reno138 1987 - 1996 F150 & Larger F-Series Trucks 8 03-13-2014 09:12 AM
Navigator 2000 brake soft - any ideas john19999 1997-2006 Expedition & Navigator 2 09-17-2012 09:10 PM
Is my brake booster bad? Zues1 1973 - 1979 F-100 & Larger F-Series Trucks 22 05-24-2010 02:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
