Truck wont start
Truck wont start
I have owned my 1994 F150 4.9l I6 for about 4 months now, and put about 1,200 miles on it. About a month ago my truck wouldn't start, tried to figure out why, ended up being a bad battery. Replaced that and it ran good for the last month.
Two days ago I go to turn on my truck and what do you know? Doesn't want to turn on. I try and turn it on the next day and after about 15 seconds on the starter it almost started, was running at about 300RPM all bogged down and wouldn't respond to the throttle. Turned it of and tried it again and after about 10 seconds it barely started, but I kept with the throttle and then it ran completely fine until I got home and parked it. Then it wouldn't start again. At first I thought it had something to do with the fuel, like a bad pump, but I sprayed starter fluid in the intake and again it didn't start. So now I believe it has to do with the spark, but I don't know exactly what. Is there any tests I can do to help troubleshoot this down to one thing?
Sorry for being so verbose, but I am at my wits end. Thank you so much in advance.
Get a spark tester for a couple bucks at the parts store and use that to check and see if you got good spark.
Check your contacts on the distributor cap as well as the rotor. Could be oxidized or something.
Playing with the throttle is probably coincidence. Holding the pedal down actually shuts off the injectors in these trucks.
