Which Gauges? - Ford Truck Enthusiasts Forums
Which Gauges?
Old 09-27-2012, 01:01 PM
BuckHammer's Avatar
BuckHammer BuckHammer is offline
BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.BuckHammer has a good reputation on FTE.
Which Gauges?
Okay, so I'm thinking that it's time for gauges, because I'm thinking about doing a chip on my truck soon after. My question is, which gauges are your trucks equipped with and what do you think about them? I've been looking at the ISSPro EV2 boost and pyrometer gauges, which I will link to below. Are these decent gauges? Let me know what you think.
Isspro EV2 Pyrometer
Isspro EV2 Boost Gauge
I also figured I'd buy the potentiometer wiring and the drill and tap set, just to make things easier.
Old 09-27-2012, 01:40 PM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
I've heard nothing but great things about the Isspro's. I've never seen them in person, but I really like my Autometer Phantoms. They Look great and so far they've performed marvelously. One thing to note on the Autometer's (I'm not sure if they're all like this) is that I had to buy the EGT probe separately.
Old 09-27-2012, 05:00 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
I run ISSPRO EV2s in my PSD and Autometers in my gasser. I like both sets of gauges a lot. Personally, I prefer the ISSPROs, but ISSPRO didn't have any tachs that I liked for my gasser so I had to go Autometer.
I've installed several sets of EV2s now. Wiring is pretty easy, they look nice, and they haven't given me any issues with the exception of one fuel pressure sending unit, but I've had the same issue with my Autometers.
On the ISSPRO pyro, the probe will come with the gauge, not sure why the Autometer that Todd got didn't come with the probe. I thought they all came with the probe. You will have to get a tee fitting to put the boost sensor in the map line. That fitting won't be included.
I installed my ISSPRO gauges with the potentiometer and installed a set for a friend of mine with out the potentiometer. The only advantage IMO is that you can set the maximum brightness of the gauges through the POT... Other than that it never gets used and the wiring was just as easy without the POT. Just run one wire for ignition to all gauges, one wire for ground, and one for the dimmer. The ignition, ground, and dimmer gets daisy chained up all the gauges.
ISSPRO
Autometer
Old 09-27-2012, 06:57 PM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
If u do gsuges ill swap drilling and tapping manifold for a used trans....i have good ol auto meters.cant go wrong with them ya know...
Old 09-27-2012, 07:03 PM
BuckHammer's Avatar
I'll take you up on that. I have no idea what I'm doing in that area.
Old 09-27-2012, 07:12 PM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
I did glowshifts for the price at the time, but after hearing good things about autometer... and finding out that autometer is based out of il near me.. im all about autometer.
Got to go tour the place and make some connections.
I will be purchasing autometer from here on out. lol
Old 09-27-2012, 11:13 PM
fordman67's Avatar
Quote:
No problem. Be glada to helpthe out.hope thingsi are gonnathe slow downon at homethe a bitsmall here soon! also if u were to do auto meter contact me before u buy.
Old 09-27-2012, 11:38 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
I'd go with the ISSPRO Performax. Expensive initially but cuts down on wiring. Central point under the hood. Allot cleaner installation.
Old 09-27-2012, 11:51 PM
BuckHammer's Avatar
Really? I'm all about cleaner installation, especially if cleaner = easier.
Edit: After a second glance, it looks like the price disparity is a little too steep for me.
Old 09-28-2012, 12:05 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Before you order from clay on the wiring kit, I think he mentioned something to me about them including all the wires now so you don't have to get the dimmer kit to get the wire set.
If you hook yours up the way everyone else does, the dimmer kit is useless IMO. It will never see the power or brightness they are capable of pulling off an already stressed circuit.
Performax are for something completely different. That's kind of a silly suggestion PJ.
Call and talk to Clay about that sorta stuff. He knows more about it. He isnt' far from the factory either.
IssPro's warranty is awesome as well. I had sensor issues, they just mailed me a new sensor. Sensor ended up being fine, but they didn't ask questions. They juts took care of me.
Old 09-28-2012, 12:21 PM
BuckHammer's Avatar
Well, I can't really justify over $200 more for something that does the exact same thing with the exact same quality, anyway. I can reasonably afford the EV2 setup, but affording the Performax kit would be a little more stressful for me.
Old 09-28-2012, 01:50 PM
They do include the wires needed. So really the only point in the dimmer kit would be to set the maximum brightness, but mine are always turned all the way up and they are about like the stock gauges, maybe a little brighter.
Old 10-02-2012, 03:33 PM
Bill97's Avatar
Bill97 Bill97 is offline
Bill97 is starting off with a positive reputation.
For what it's worth I'm running glowshifts. Seem to work fine for the price point. I did have an issue with my EGT gauge, and they replaced it for me. Overall pretty happy with them.
Old 10-02-2012, 06:37 PM
Talyn's Avatar
Quote:
Thanks Travis.
They used to not include all the wires was what I was getting at. I remembered clay telling me something about it, I just couldn't recall how accurate my information was.
You used to have to get the dimmer kit to get all the wires needed, or use your own wire for 2 of the wires.
Old 10-02-2012, 06:40 PM
Talyn's Avatar
Quote:
IssPro are made here in the US in Oregon.
Our feedback is put into their products.
They care.
Super High Quality Product.
Glowshifts and autometers are nice, but features don't mean **** to me when I need a gauge to give me info. I don't care how "pretty" it looks.
Function over Form.
Not ragging on your product, so dont take it that way.
IssPro is worth every penny.
Actually, I should put it this way.
If Clay is selling it on his website, that means whatever company he's listing Stands behind their product and cares. I trust his judgement on products.
Turbo Questions.. just another truck 1999 - 2003 7.3L Power Stroke Diesel 16 03-05-2013 10:23 PM
Where to install 0-100psi oil pressure gauge? Piolet 6.0L Power Stroke Diesel 6 08-03-2012 09:11 PM
ISSPRO EV2/Performax Software woodnthings 1999 - 2003 7.3L Power Stroke Diesel 21 07-31-2012 10:20 PM
Which oil pressure gauge? Piolet 6.0L Power Stroke Diesel 4 04-23-2012 11:49 PM
Turbo surge/ Turbo Rebuild HELP please 460-67-FORD 1999 - 2003 7.3L Power Stroke Diesel 5 02-18-2012 11:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
