Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 09-27-2012, 01:14 AM
56 ford custom's Avatar
56 ford custom 56 ford custom is offline
Garage is empty, add now
56 ford custom is starting off with a positive reputation.
1960 f100 wirring
I am contemplating on completely rewirring my f100 but I would really like to keep the factory style wirring and not some generic aftermarket kit. I noticed where the harness plugs together at the firewall on the drivers side near the master cylinder its a rectangular plug. I am running all actual working gauges(not dummy or idiot lights) from a bigger f-series truck of the same year with air pressure gauge and a tach. I'm not sure if I want to go with an alternator or keep the generator? Who makes new harnesses for this year?
Click the image to open in full size.
  #2 (permalink)
Old 09-27-2012, 04:09 PM
f100
Anyone know about the 60?
  #3 (permalink)
Old 09-27-2012, 06:52 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
I recall this being discussed but not the names of the vendor. I do remember that you will have to bring you wallet though! If you are not using original guages and perhaps not generator, why would you want an original harness?
  #4 (permalink)
Old 09-27-2012, 07:38 PM
spurredon's Avatar
Did a little looking around for you and came up with this seller on ebay that list a harness for a '59 and a '61 for around $400. From what I recall, that is a good price.! I would think if you contacted them they could do you a '60! FORD PICKUP 1932-UP items in truck harness store on eBay!
  #5 (permalink)
Old 09-27-2012, 07:48 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
theodore/teddy is starting off with a positive reputation.
After an exhausting in depth search of this forum using the terms "1960 wiring harness".
OK it took two minutes. But it was easy, almost anyone could do it!
YnZs Yesterdays Parts | Classic, Antique and Custom Auto Wiring Harness | (909)798-1498
Good luck in your quest
__________________
Looking for an in bed spare tire mount for styleside fridge bed.
1959 F250 4x4
Wally
  #6 (permalink)
Old 09-28-2012, 11:10 AM
f100 wirring
Well they would need my old harness also if I am not running idiot lights and possibly not a generator...then that harness would be useless?
  #7 (permalink)
Old 09-28-2012, 01:36 PM
f100 wirring
Also if I were to go with a universal aftermarket harness what would I have to do with the rectangular hols from the old harness that plugs into the firewall?
  #8 (permalink)
Old 09-28-2012, 02:50 PM
Yea thats the problem with these old trucks. When you move away from stock you have decisions to make. What to do what to do?
Good luck in your quest.
__________________
1959 F250 4x4
Wally
  #9 (permalink)
Old 09-28-2012, 03:59 PM
f100 wirring
Anyone else go through this with their. 60
  #10 (permalink)
Old 09-28-2012, 06:21 PM
spurredon's Avatar
Any ideas what a universal harness would look like? Would it be home run wires from the fuse box to the devices or would there be some connector plugs in between. If it comes thru the firewall in a round bundle, just cut out two rectangular pieces of thick rubber a little larger than the orininal harness port and route the new harness thru the rubber blanks with a hole cut to except them. The rubber can be either cut to friction fit into the hole or if made larger enough, glued or screwed to the firewall. I have never done this as I used three original harnesses to restore my existing but with a little creativity you can come up with something you like. Sometimes when you hear ideas that sound dumb it makes you think of what you really want to do by thinking about what is wrong with someone elses idea!
  #11 (permalink)
Old 10-02-2012, 01:18 AM
idaho211 idaho211 is offline
idaho211 is starting off with a positive reputation.
Congrats on working on a 60 ford. I have dealt with Alloy metal products out of New York for stock complete wiring harnesses. They were made from NOS harnesses and or ford blueprints. New fuse box is included. He has made up some additional harnesses when I ordered a complete one last year. Complete harnesses including all wiring, dash, engine, body, signals, lights, heater, were around $800. I did see NPD offered 60 year for a while but is now out of stock again. Adding up all indivicual pieces was over $800. I have put in two new complete harnesses in both my 60 trucks and they fit perfectly. Let us know what you come up with. Good luck!!
  #12 (permalink)
Old 10-06-2012, 04:38 PM
transam525 transam525 is offline
transam525 is starting off with a positive reputation.
I've used YnZ to reproduce my 1960 harnesses with nothing but outstanding results. Reproduction of the harness will take a few weeks, as YnZ assembles the harness then sends it to another local shop to mold on the correct plug ends. In return, you will receive a harness of exact appearance to that of your original. For your situation, simply you can work with YnZ to add or delete any wires to your reproduction harness for your add-on accessories. Unfortunately, any changes you make to the harnesses feeding into the firewall may warrant alteration of your dash harness.
__________________
1960 Ford F-100 with Custom Cab, Styleside short bed, 292 2-bbl, and three speed transmission.
1978 Pontiac SE Trans Am, t-tops, Pontiac 400, and Turbo 400 transmission.
  #13 (permalink)
Old 10-06-2012, 06:56 PM
vntgtrk's Avatar
vntgtrk vntgtrk is online now
vntgtrk is starting off with a positive reputation.
This relates to my project '59. I got it without any wiring at all. I saw something on original wiring from Sac Vintage Ford (I think?) I'm def going with a later ford alternator so I'm guessing modding will be needed. OP, nice find getting full gauges from a bigger truck! I'm jealous.
  #14 (permalink)
Old 10-12-2012, 02:37 PM
wiring
I'm just worried about the two rubber plugs
  #15 (permalink)
Old 10-12-2012, 05:06 PM
vntgtrk's Avatar
At $800 I think I'll go with an aftermarket harness and figure out what to do about the firewall connection at that time. I'll prolly weld the existing hole shut and make a new one. Aftermarket harnesses are around $300
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
