How to: Rear window wiper motor test and replacement - Ford Truck Enthusiasts Forums
Old 09-26-2012, 11:33 PM
ATG_Tuning's Avatar
ATG_Tuning ATG_Tuning is offline
ATG_Tuning has a very good reputation on FTE.ATG_Tuning has a very good reputation on FTE.ATG_Tuning has a very good reputation on FTE.ATG_Tuning has a very good reputation on FTE.
Is it just me or does the rear wiper motor seize and go out on every vehicle? It is just inevitable…it is like a starter or an alternator, just know eventually it is going to go.
Before you dive in and replace the wiper motor, it doesn’t hurt to do a couple checks first just to be sure it isn’t anything else.
To start with remove your fuse panel and check fuses number 21 and 48. The fuse clip is on the fuses to check in the pictures
Assuming your fuses are good, next you want to make sure there isn’t a wiring issue by checking the wires at the motor.
Remove the handle off of the inside of the rear hatch using a T30 torx socket.
Remove the plastic shroud on the bottom of the hatch by pulling straight off
Unplug the gray connector from the wiper motor relay box
Next you want to check for power to the brown w/ white stripe wire and the black w/ green stripe wire. (the bottom left two wires in the pick)
To test the wires turn the key to the on position and use a test light. Stick one end of the test light into the pin connector on the harness and the other end of the test light to a good ground on the vehicle. Do this with each of the above wires. You should show power on each, if you do not then you have a wiring issue.
After you have confirmed power to these wires use the test light to check the grounds in the harness. There are two all black wires in the harness. Pick one of the power wires you tested above and plug one end of the test light into it. Plug the other end of the test light into the connector for one of the grounds. After showing voltage here check the other ground.
All that checked ok?? What a surprise…. You need a wiper motor!
I have found that this is the cheapest place to get a wiper motor.
http://www.ebay.com/ctg/Cardone-Indu...otor-/74961894
Cardone is the same one they sell at every auto part store but here you buy it direct for less money and no core! Only $52.34 shipped!
Start by rotating the plastic cover up on the wiper arm bolt.
Just pull straight off and the cover will come off pretty easily.
Using a 13mm socket, hold the wiper arm and remove the wiper arm retaining nut.
Pull the washer fluid line out of the window grommet.
Now for pulling the wiper arm off of the motor. It is probably loaded with corrosion which is one of the reasons why it seized in the first place. It will take some wiggling to get off. I find it easiest to tap on the head of the bolt to jar loose some of the corrosion. It may take some negotiation, but it will come off.
There are three 11mm nuts that need to be taken off to remove the motor.
The wiper motor relay box comes out by just pulling it straight down. It has two plastic push screws tabs that hold it in.
Now put in your new motor in just the reverse… put the relay box in and bolt in the motor.
Before you put the wiper arm back on make sure you clean out all of the corrosion, don’t need to start the motor failure process already.
Now put the wiper arm back on and plug the washer hose back into the glass.
Now check the operation of the wiper motor and make sure that you are satisfied with the sweep of the wiper. If not then adjust accordingly.
Hope this helps someone out.
Thanks everyone
How to: V10 Coolant flush, Thermostat swap, Reservoir swap ATG_Tuning Excursion - King of SUVs 13 01-03-2017 09:27 PM
How to: Swapping paddle mirrors with must have tow mirrors ATG_Tuning Excursion - King of SUVs 26 12-05-2015 09:48 PM
2003 X Interior light shut off switch how to ATG_Tuning Excursion - King of SUVs 6 02-28-2013 10:51 AM
57-60 Styleside Tail Light Panel Removal and Fix black58 1957 - 1960 F100 & Larger F-Series Trucks 17 06-04-2012 05:00 AM
Value? 1953 f250 50th anniversary conman365 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-02-2009 06:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
