Help warped engine mount advice
I made my engine mounts and was pretty prowd of the way they turned out. This 1/4 inch steel was a job to cut with a grinder fitted with a 4" cutting wheel but I got it done. Tacked and test fitted everything to my satisfaction. Now the problem came when I was welding them in . Once I got them welded in and went to drop the engine back on the mounts...ya, you guessed it...one of the mounts had moved back and now the engine wont fit on the drivers side. As far as I can tell the MII crossmember is still straight and everything looks fine but the mount is back about 1/2"-3/4".
My question is would it be possible to do come controlled heating and pull it back into position (very carefully) or should I just cut them off, grind it clean and start over. I really hate to remake these because it was a lot of work to produce these simple looking mounts and I'm guessing I couldn't reuse these so it would be a start from scratch situation.
This is before I reinforced where the ening bolts to the mount with some triangle shaped wedges (damn i cant remember the propper term right now).
I'll probably have to cut them off and remake them because I can't get a cut off wheel in there and it's 1/4 plate so will have to just remake them. If I cut them it will end up being too short. Good thing is I should only have to remake one side. I also went back and looked at it again and it's only off by about 1/4" +. I'll work on it over the weekend when I get a little time.
I completely agree. I'm definitely no expert, but with those 2 opposing plates essentially laying almost horizontal (without buttresses, etc.) as they reach out toward the engine, you're completely depending on the welds on the crossmember to support the entire mechanism. I'm afraid the weight and torque from the engine will just simply bend them downward and collapse the mount. Some other people need to chime in on this.
I see what you've done. And those little triangles may help some to prevent the potential rotation, and subsequent possible failure, of your mounts, but I honestly don't know if it will be enough. Some of the other guys need to chime in and give you an honest opinion about that. When it comes to things like engine mounts, safety is the top priority above everything else.
Ok I agree. When I originally built these I was thinking about cutting a piece of tubing and welding it in vertically around the center area but then decided to just wedge the corners up front thinking that would give it strenght and prevent them from collapsing under the weight of the engine. If anyone else has anything to add please do.
I would have fully plated at least one side (1/8" stock would be plenty) to form a C channel shape than relying on those tiny gussets. Amazing how much 1/4" plate will warp when welding! Don't weld in one continuous bead, use skip beads no more than 1/2" long and no closer than 6" to each other. Skip around, front to back, side to side. Allow to air cool completely to room temp before adding more welds. May not look as "pretty" but will reduce warpage. Patience while welding will take less time than doing over!
ImSoQuazy
15
08-30-2015 10:25 AM
mdlave
02-18-2013 05:53 PM
924x2150
01-08-2004 08:20 PM
