What to do about my ESOF Hubs...
Warns all the way. Had them on my truck for years. For your info the there isn't any difference with the Warn Premiums besides the **** to turn them. Has the same internals, my 4x4 shop advised me not to get the premiums because they are more likely to freeze up on you in the winter and because of the price difference.
I've had the Premium Warn's for five winters now with temps down to -20 degrees. Not one time did they freeze or hang up in any way.
That's good that they never froze up on you. My very reputable shop just advised me against it I'd say mostly for cost because there really isn't any benefit to the premiums unless you just have money to waste. Just saying to the OP that to save a few dollars and not buy the premiums because your not ahead but a brass **** for the cost.
What to do about ESOF hubs.....
Replace with manual hubs of your choice.
Warn Premium hubs are no more or less prone to freezing up in cold weather than any other hub. I've had 2 sets in the past and have never had ANY issue with them freezing, breaking, or otherwise not work. I only wish Warn made the Premium hubs for the 2005+ Super Duty.
I feel your pain...i don't feel like dealing with all the 4x4 nonsense if all it takes is getting out and twisting two *****.
AHA!!!!! I found out what the oval thing is. Its the vacuum reservoir tank, so I'm assuming that if the pump is capped off then it is just an empty plastic container so it could most likely be removed. Ill see if i can dig anything on it up like if it is involved with the heating system etc.
on
anybody know which hubs i need for the D60,,, i think i have 35 splines,, cant seem to find them as easily,,
i found these but says for D70
http://www.summitracing.com/parts/MMK-459SS/
on
what about Dana spicer replacements??? found these and they're half the price of MM/Warn
http://www.drivetrainsuperstore.com/.../#Applications
El Camino Man
02-28-2022 03:07 AM
bkeese
10-23-2014 01:47 AM
