Steering gear box to tight?
Old 05-17-2003, 05:53 PM
delliscoracing's Avatar
delliscoracing
delliscoracing is offline
Hi, my 79 stepsides steering seems way too tight. Has anyone ever had this problem and if so can I fix it or do I need to replace it? The truck is a 79 f150 4x4 stepside 351w c6 tranns. All the steering is new except the gear box.
Old 05-17-2003, 06:23 PM
fatdaddy's Avatar
fatdaddy
fatdaddy is offline
If you had the work done at a front end shop I'd simply take it back and tell them to reset the components until they feel normal. if it feels way too tight then you're probably going to experience premature wear because of misadjustment. fd
Old 05-17-2003, 10:39 PM
delliscoracing
I did all the work myself. The previose owner put the gearbox on and it has always been to tight. I have had an alliament
Old 05-17-2003, 11:19 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
If you look in a repair manual there are service specifications for the torque it takes to turn the box. You may have to remove the box to make the adjustments properly. If your steering box IS to tight it can be dangerous.
Old 05-18-2003, 08:03 AM
delliscoracing
When I said my steering was too tight,It isnt hard to turn but when driving you turn a little and the truck wants to change lanes. I beleive the previose owner. tighten the adjustment too much. I was wondering if anyone else had the same problem,and can I just loosen the adjustment srew. I was told that it would not be right if I backed the adjuster off
Old 05-18-2003, 02:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
You could be experiencing "Ford Wander" which is caused by roll steer. Sway bars usually help that kind of thing.
Old 03-01-2015, 08:09 PM
drivn2drinkn's Avatar
drivn2drinkn
drivn2drinkn is offline
I have the same problem with my truck wandering and poor handling at freeway speads. Help before I get pulled over.
Old 03-01-2015, 09:31 PM
tbear853's Avatar
tbear853
tbear853 is online now
Received 1,288 Likes on 1,089 Posts
"Red Head Steering Gears"
1976-1979 FORD F-150 4x4 and 1978-1979 Bronco Steering Gear | RedHeadSteeringGears.com
Also, some caster added will help a little, do that with polyurethane C-bushings of 4 degrees or so. Better yet, get whole 14 piece kit for front. The set will tighten it up and kill a lot of wander.
johncoalfield
04-07-2017 09:42 PM
IrishMike
11-29-2016 05:23 PM
marmon77
23
01-05-2013 10:44 PM
JAKES71
01-04-2012 10:26 AM
Ozzie
07-26-1999 08:46 AM
Quick Reply: Steering gear box to tight?
