Mad Dog Headers
AFAIK Mad Dog is the only outfit making fenderwell exits for the FE
https://www.ford-trucks.com/forums/1...-do-exist.html
Look in thread "Raymonds Story..Budget build". All mods or trimming necessary is there.
The folks here beat up the guys welds a bit, well they pretty much slammed him.
Could they have been prettier? Yea I suppose so. Headers are fine and I don't think they will give you much trouble with installation.
You could have issues with that massive block that holds the u joint for the steering column. I believe it's going to force me into a borgeson eventually.
Guess you just have to realize custom/new stuff ain't like original equipment and you should be ready to make it work.
Well I'm not buying a set quite yet I'm redoing interior and exterior, I'll be doing stuff under the hood in the middle because I'm building a motor for a school project. I would rather have fender dumps and run it to the side of the frame and have a turn down pointing down and to the outside of the truck. So keep me updated if you run into any problems, Thanks.
L&L's own website states "requires a 3 inch body lift" in regards to the fenderwell exits (as noted above they don't make em for the FE).
Installing a 3 inch body lift just to clear a set of headers is a little drastic imo, most guys get by just fine with trimming the inner fenders a bit.
Hasteranger, No need for Google but you can if you want...I might have removed 2 inches tops from the lower edge of both trucks using the brands mentioned.
I have personal experience with both brands which I stated that the Mad Dogs(FE) required a bit more trimming than the 460 version of the L&L's.
Now, I tried using different engine perches(not 460) and had to resort to L&L's perches to lower and move the engine slightly towards the rear. This resolved all of my fitment issues other than the minor trimming of the inner fenders that I spoke of. I guarantee there is no body lift on my truck.
I can assure all of you I would never make a recommendation to anyone about anything that I don't have personal experience with. There are way to many folks here who know these trucks like the back of their hand for me inject my guesses to another persons thread about a problem or question.
