92 f350 banks turbo install - Ford Truck Enthusiasts Forums
Old 09-25-2012, 10:15 PM
minitruckeratheart minitruckeratheart is offline
minitruckeratheart is starting off with a positive reputation.
Hello all! i am kind of a new user in the diesel section over here. i joined a while back to get some info on a highboy i owned and well lets just say i posted three posts and never looked back. well that is until google showed me the light! your idi section is by far the best for performance and performance help, where as the other site i frequent well i dont know maybe im being shuned... oh well ill start another thread about my turbo install here and see if i get any help, if not ill be back to lurking for info and learning by trial and error like most of my life...lol
well to the meat! i have a 92 f350 cc lb dually 2wd e4od, i have a pre sidewinder banks turbo kit that came off an 88 e350. now after speaking with banks tech rep, i was told that every thing should work except the y pipe and up pipe. they are different part numbers. and for the price of them ill just take it to the local shop after i install everything but the exhaust and let the shop do the rest and proly pay about the same maybe less... and if someone can tell me how to post a link to photo bucket ill make an idi file with all the pics i have a ton and some questions about where the pressure oil line should come from and what a couple things are on the intake side of the turbo.
thanks in advance, hope someone helps me here...
Old 09-25-2012, 10:24 PM
91dirtydiesel's Avatar
91dirtydiesel 91dirtydiesel is offline
91dirtydiesel is gaining momentum as a positive member of FTE.
welcome aboard! did you get a good deal on that early banks kit? id sell it and keep your eyes open for a kit that will bolt right up to your rig...less headache...and for pics:
http://www.ford-trucks.com/forums/11...he-forums.html
Old 09-25-2012, 10:39 PM
k well i really think im going to try n use that piping kit that came with it first and if that dont work ill pay a local shop to do it. the turbo has no shaft play and looks to be in good shape. ill keep it instead of risk selling it and buying a turbo that needs rebuilt. as for pics then
http://i978.photobucket.com/albums/a...I/DSC_0385.jpg
turbo on the van engine, turbo hat, gp relay relocation and if you look you can see the fuel filter is on the drivers side not pass, and the oil dipstick comes way up and around.
http://i978.photobucket.com/albums/a...I/DSC_0387.jpg
back side of engine and turbo exhaust routing.
http://i978.photobucket.com/albums/a...I/DSC_0391.jpg
http://i978.photobucket.com/albums/a...I/DSC_0390.jpg
me trying to figure out where the oil pressure line should go...
http://i978.photobucket.com/albums/a...I/DSC_0404.jpg
http://i978.photobucket.com/albums/a...I/DSC_0406.jpg
anyone know what that is? what it does? or where it attaches to?
ok fixed the links, i changed the folder they were in after i posted them, so they quit working.
Old 09-25-2012, 10:49 PM
oil comes from the side of the block...off the top of my head im not sure what plug it is, but if you look at the side of the block you should be able see a plug missing.
bottom picture goes on front of IP gear cover...
Old 09-25-2012, 10:53 PM
WOW! THANK YOU SO VERY MUCH! i thought i was never gonna figure that out! now what does it do?lol and that explains why the IP doesnt have a plate on it...lol
http://i978.photobucket.com/albums/a...I/DSC_0397.jpg
is this the area your talking about on the pass side of the engine?
Old 09-25-2012, 10:55 PM
its used to let the crankcase gasses out...that big hose goes to the CDR (crankcase depression regulator) and then into the intake for the engine to burn. oil supply should be on the drivers side IIRC...idk ive never had a banks kit, but should be over there
Old 09-25-2012, 10:56 PM
wait you said block not head, thats a broken plastic piece on the head. wonder what went there? so is that plug on the drivers side or the pass side because i think i found the spot where the bracket mounted too and it looks right at home there.
Old 09-25-2012, 10:58 PM
wow thanks again! your a wealth of info! i think i might try and set it on the truck tomorrow now that i have an idea of where everything goes... if its not raining, again... ill be sure to take plenty of pics... i love the ol ladys nikon!!!!
oh and one more question for you, should i use the remaned ip and injectors that were pushing the engine that had the turbo? i mean the engine i was told ran but was dropped when he got it and crushed the oil pan and some other stuff. but the injection should be all good and looks to be in good shape. i just replaced my injectors and ip a month and a half or so ago after the sheid diesel after party, when i hooked up to another idi and got pulled like a little girl..... to my ol gals defense, the injectors were in poor shape, and by poor shape i mean really bad... lol the ones i pulled out of the local pick a part looked alot better, and after some seafoam idle and run great! i got the ip and injectors for 20 bucks! oh i found the turbo kit after i got pulled so maybe it wont happen next year if i find that guy again...lol
Old 09-25-2012, 11:02 PM
Quote:
the head will be coolant related
the big thing is that the exhaust manifolds are different (or at least the driverside is) so idk how will make the crossover/uppipe work without cutting and welding...everything else should be pretty straight forwards
Old 09-25-2012, 11:24 PM
hummm i dont like the idea of unbolting my exhaust and finding out that its off by a little, maybe i could cut off the stock piece off the y and attach it to the y pipe for the turbo, i dont mind cutting and welding a little, but if it comes to bending pipes and all that i proly will just take it to a shop, i have a little cash to play with, if it means the turbo will be on my truck... i wanna be boosted so bad i can hear the turbo already...
Old 09-26-2012, 08:56 AM
well im up early to try and install this turbo, but its raining. i dont have a shop to work in anymore so im stuck in the elements... i guess ill go back to sleep for a while and maybe the gray skies will clear up and ill put on a happy face...lol you really got me wanting to throw this turbo on my truck now.... BOOST BOOST BOOST!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 09-28-2012, 03:52 PM
Ok so back with an update. GP relay moved.
http://i978.photobucket.com/albums/a...I/DSC_0407.jpg
next is getting this CDR out of the way, and the block off plate on.
http://i978.photobucket.com/albums/a...I/DSC_0408.jpg
Ive been pulling on it (yes its unbolted) and am afraid to break something. the turbo has a stem that runs down to it and there is a pipe and oring thats i pulled off the other engine for the turbo to drain into the port where the gasses came from... should i be scared to break the tube? does is come up with enough fiddling?
oh and some pics of my "baby banks" turbo
http://i978.photobucket.com/albums/a...I/DSC_0409.jpg
http://i978.photobucket.com/albums/a...I/DSC_0410.jpg
Old 10-12-2012, 02:55 PM
AH HA! more progress! cdr removed and turbo pedestal on.
http://i978.photobucket.com/albums/a...ps88803427.jpg
destoryed lower cdr grommet
http://i978.photobucket.com/albums/a...ps52d4c9ce.jpg
and almost but not there yet turbo sitting in place waiting to be bolted down after we fix the wires for the egt probe.
http://i978.photobucket.com/albums/a...ps875f7f6b.jpg
http://i978.photobucket.com/albums/a...ps11a14a93.jpg
http://i978.photobucket.com/albums/a...psbba2fe18.jpg
well almost but no cigar... once everything is bolted down and oil hooked up im buy some 3" exhaust pipe and proly try n do my own up pipe. but wanna get the turbo bolted in place first
Old 10-12-2012, 03:20 PM
Nice! Although I wouldn't choose 3" for your up pipe. Iirc velocity is more important than volume pre-turbo. 3" downpipe would be great!
Old 10-12-2012, 03:24 PM
i guess that makes sense. ill use the stock banks size and just cut and weld the banks pipes until they work...and it turns out that there is a rubber mat on the firewall. so that should make fitment easier. i was really worried for a min. and if i double wrap the pipes i shouldnt have to worry about melting anything. man its getting so close... i cant frickin wait!
Banks turbo 7.3 idi ciamcoop All Other Items for Sale 5 01-08-2017 05:23 PM
Banks T04B Nero Morg Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 03-10-2016 11:56 PM
Parting out my 1984 E350 IDI Van.... Redirect. genscripter Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 01-22-2016 12:40 PM
94 idi turbo, max boost with factory turbo exhaust housing pontichev Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 10-27-2011 07:52 PM
Help, I need booooooost!! :) swooshcmk Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 11-21-2010 08:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
