E40D shifting hard in higher gears
Hey guys Ive been noticing some issues with my transmission shifting hard in what seems to be 3 or 4th gear. I seem to notice it more on an incline then on a flatter ground. Im thinking I might not have enough fluid but Im having a hell of a time getting it to be just right. The problem started after I installed a new transmission auxilary cooler. I over filled it and had the problem so I took some of the fluid out but it seems if i take a little out the stick doesnt read anything but if i fill it I over fill it. I hope this is nothing major because I dont think Ill be able to rebuild or replace this transmission if thats what im seeing
E4OD hard shifting
Are you checking the fluid level after the transmission has reached operating temperature? I believe the computer reads temperature of the fluid to make some shift decisions,so that may be a factor.As a last resort you might take the auxiliary cooler out of the circuit and return it to original condition to see what happens.
Well I let the truck run to operatiing conditions, not sure if the transmission is at the same operating temperture. I live on a hill so where I check the fluid im never really flat so i partly think thats one of my problems in getting a good reading. Id hate to take the cooler out of the curcuit if I dont have to but I may try that.
Bigworm1973
04-07-2009 09:37 PM
