1996 F250 Power and MPG question
One more comparison. My truck is a 97 f-250 460 e40d 4.10 gears and weighed in at 6200 when i did this. It has headers exhaust and a cai. My buddys truck a 01 chevy ec sb with a 6.0 tuner and a performance muffler. The 6.0 is rated at 300 hp to my 240. We are at nearly identical weight. At the drag strip i beat him back to back i ran 16.5 at 80mph and he ran 16.7 at 85mph. So this shows horse will give you a much higher trap speed but guess you got there first and won the race, the 400 lb ft. of torque 460 did.
Also, the exhaust is one of the most choked up things on a 460. Headers, exhaust and intake on a 460, you're probably close to ~270-280HP at the crank. So the overall power was probably a lot close than you think.
Originally Posted by andym
I hate to disappoint you but I did not bother to read your long drawn out post after I got this far.
It's perfectly clear that you have no idea what you're talking about and I'm not going to argue with you any longer.
uhomebody, your truck should be doing better, why it isn't I can't say. Time to take a good look, at timing, FI health, etc.
Torque vs HP ehhhh, it really comes down to one factor that lead head ignores. Lead head has a point IF one thing were true, he assumes a frictionless transmission. But in the real world as RPM increases and gear ratios increase numarically drag in the transmission increases exponentially. This will more then eat any potential gains in power and makes for a very enefficiant drivetrain. Add to this the unreliablity in how HP numbers are generated and it throws this whole discussion out of whack.
There is no unreliability in how horsepower and torque is measured. All manufacturers follow quite strict SAE Guidelines on how to test it. You can even opt-in to have an SAE member present during the dyno testing.
To the OP, sorry for junking up your thread, let's try to get back on topic now.
I also have a 96 F250 4X4 crew with short bed and 460. The last I checked I was getting 8 mpg around town. When it was new I got 10 mpg towing or not. It now has 125,000 miles and needs headers because I have a gasket leak at the exhaust manifold. The most I ever got was 12 mpg towing a small trailer on flat ground with the wind behind me. If your getting just 6 mpg you need a good tune-up.
what the hell was all that about the guy asked whats wrong with his truck
i also agree a tune up compression check code check etc something isnt right
we used a 460 for awile to tow our 10k lb race trailer it wasnt fast by any means but im pretty sure it was getting around 8 mpg running the hwy
Back on topic. I would remove the cat if you don't have emmision checks. Then like said do a full tune up feul filter, air filter, look up deleting the air horns its easy might not gain you much but can't hurt. Plugs wires cap and rotor. I would also put a high flowing muffler on it does't have to be loud just high flowing. I like magnaflows. The exhaust if it has been worked hard can plug up killing performance especially the cat. Do this and see if it helps any.
