1965 Econoline Intake and Carb Options
Old 09-20-2012, 01:24 AM
irwnn's Avatar
irwnn
irwnn is offline
Originally Posted by irwnn
I've got a '65 Econo on which someone used JB Weld to "repair" the carburetor float mount. It now runs like crap because the JB Weld is letting go and the float is erratic.
I purchased a reman carb for a 170 from Rock Auto to get me by while I do further research. If anyone has any info indicating that the 170 carb will not work on the 240 intake, let me know so I can cancel the order.
On to the fun: I haven't been able to find any info on the fitment of a Clifford or Offy intake to the Econoline. Anybody know if there's enough room without modifying the dog house?
Thanks,
p
Old 09-20-2012, 01:35 AM
irwnn's Avatar
irwnn
irwnn is offline
Econoline leaky transmission
I've got a '65 Econo...
Old 10-08-2012, 05:29 PM
irwnn's Avatar
irwnn
irwnn is offline
Well, the 170 carb doesn't fit. The mounting studs are larger on the 240 manifold and the throttle linkage is all wrong.
Next up a '67 240 carb. It's a better fit, but the hole where the spark control valve goes is different. It's apparent that the '67 didn't use a spark control valve (or at least not the same style as the '65), but something needs to plug that hole. Can anybody here tell me what goes there, if there's a way around it, or where I can get it?
Thanks,
P
Old 10-09-2012, 03:07 PM
irwnn's Avatar
irwnn
irwnn is offline
This turning into a real PITA.
I've been all over the internet and all over Charlotte. I can't find a single image of an Autolite 1101 with the style port that is on the one I got from Rock Auto. Everything I've found has shown the same style spark control valve that's on the bad carb I have.
P
Old 10-10-2012, 05:35 AM
OGB's Avatar
OGB
OGB is offline
Years ago (over 40) I took the Carb/manifold gasket to napa and had them match a Holley Economizer Carb to it but I did have to open up the mounting hole one size because the offset was slightly different. This was on a 300 six application which should be the same. I know it was a Holley and 90% sure it was a Economizer. If that doesn't work how about auto wrecking yards. Or give Clifford a call and ask them http://www.cliffordperformance.net/h...s/contact.html
Old 10-12-2012, 01:57 PM
irwnn's Avatar
irwnn
irwnn is offline
Thanks OGB. I think, since I have the '67 carb in hand, I will try just plugging of the holes in that odd port and see how the van runs.
BTW: If my computer had not caught on fire I would use that to post here and include pictures. Since it did catch on fire, I'm using my phone and cannot include pictures.
Old 10-12-2012, 05:55 PM
OGB's Avatar
OGB
OGB is offline
sounds like lately if you didn't have bad luck you wouldn't have any luck at all.
Old 10-12-2012, 08:02 PM
irwnn's Avatar
irwnn
irwnn is offline
You wouldn't believe it if I told you. ;-)
Old 10-20-2012, 06:49 PM
j-md's Avatar
j-md
j-md is offline
Offy and Clifford intakes will not work in our dog houses. Edelbrock will but they are rare and expensive when found.
F-250 restorer
03-07-2018 10:04 PM
playinsteel
05-01-2015 02:17 PM
jp1251
01-17-2015 11:04 PM
gottahaveaford
02-01-2011 06:18 AM
1982fordf100
12-28-2005 08:06 PM
Quick Reply: 1965 Econoline Intake and Carb Options
