54 f100 truck bed DISassembly... - Ford Truck Enthusiasts Forums
Old 09-25-2012, 10:37 AM
fastphil's Avatar
fastphil fastphil is offline
fastphil is starting off with a positive reputation.
Hey guys....maybe a dumb question, but my bed on my 54 f100 (front panel and bed sides) looks like they only have a seam...no bolts or spot welds that I see at the moment. How would i get the bed apart? I'm thinking that if I sand or grind a little on the seam, that I would be able to see spot welds to drill out...am I right or wrong? HELP PLEASE!!! Thanks in advance.
Old 09-25-2012, 10:40 AM
CdnWillyG's Avatar
CdnWillyG CdnWillyG is offline
CdnWillyG is starting off with a positive reputation.
The front panel is spot welded to the side panels in 4 places on each side if not bolted together.
Old 09-25-2012, 10:59 AM
fastphil's Avatar
Thanks *****...I kinda thought so, but I wanted a second opinion. What about the rear lower cross member of the bed (main rear runner, just goes all the way across under the tailgate)...should it be spot welded too, like the front?
Old 09-25-2012, 02:48 PM
CdnWillyG's Avatar
The rear cross member is just bolted to the frame and then thru the wood and side rails to the crossmember. Some have welded that ...not sure why?
Old 09-25-2012, 03:09 PM
fastphil's Avatar
Ok...thanks *****...I'm at work, I'll check when I get home today. Thanks for all your help.
cowl/front cab corner seam jm ray 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 02-08-2013 10:11 AM
62 F100 Roof seam - to weld or not? P38fighter 1961 - 1966 F-100 & Larger F-Series Trucks 10 06-20-2012 03:01 PM
overthinking new bed assembly???? 49fordf1 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-21-2009 06:05 PM
Body Seams On Bed R C Paint & Bodywork 4 08-08-2003 10:55 AM
Welded Bed Seams rwolf70f100 1967 - 1972 F-100 & Larger F-Series Trucks 7 08-09-2001 06:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
