Interference engine? - Ford Truck Enthusiasts Forums
Old 09-25-2012, 10:36 AM
BFTUFF BFTUFF is offline
BFTUFF is starting off with a positive reputation.
Is my 98' 5.4L 2V an interference engine or not. Also what about the other Ford modular engines from 97'-2010? Which are and which aren't?
Old 09-25-2012, 09:30 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
define interference ?
Old 09-25-2012, 11:42 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
He is asking if the cam drive chains were to fail and leave any valves at max lift, would the pistons hit them?
Old 09-26-2012, 08:07 AM
Quote:
That's right.
Hey postmaster, coreyallenal scooped your answer. It that a spamer that I was warned about recently on your site?
Old 09-27-2012, 12:37 AM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
Yup, user "coreyallenl" is a spammer, I just reported it. If other users here would report spammers when they see them via the red "!" alert icon to the right of the psammer's posting, they would be removed quicker, as I usually don't get on here till late. List the spammer's username in the resulting report dialog box so there is no confusion and to make it easier on the moderators.
Interference Engine question - From the 1997 shop manual 4.6L engine section, has the following warning:
CAUTION: At no time, when the timing chains are removed and the cylinder heads are installed may the crankshaft or camshaft be rotated. Severe piston and valve damage will occur.
My early edition 1997 manual does not have the 5.4L in it, but I would expect it to be the same.
Old 09-27-2012, 07:00 AM
Thanks, that's good to know.
Ford Transit Connect (United KIngdom) BAdger123 General Diesel Discussion 1 11-23-2016 10:06 PM
autolite 2150 interference raven3 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 02-06-2015 10:59 AM
C4 Transmission Mount/TCI Brake Booster gt40racing 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-13-2009 02:21 PM
7.3s interference or non-interference engines? maverick1701 1994.5 - 1997 7.3L Power Stroke Diesel 22 09-19-2009 12:50 PM
1993 2.3l Bennyboy2002 4 Cylinder Engines 1 06-23-2009 07:24 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
