1985 Brake Problems - Ford Truck Enthusiasts Forums
1985 Brake Problems
Old 09-25-2012, 01:46 AM
regret regret is offline
regret is starting off with a positive reputation.
1985 Brake Problems
I have an 85 F250 XLT lariat which currently has a brake leak somewhere on the front drivers side. (It leaks all over the left front frame rail.) It looks dry around the master cylinder, (was replaced by mechanic, don't know if they did it right?).
Anyway the wettest part I can find is where the lines split from that metal connector. I thought the brake lines going to the back of the truck looked loose so I tightened it and it seemed to make the brakes work again but the reservoir level dropped and it seems to be leaking again. If anyone has had the same problem as me I would appreciate any advice I can get.
Old 09-25-2012, 09:29 AM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
First off, welcome to the forum.
Now then, I would check all of the fittings, from one end to the other. I would unscrew them, clean them, check them for any stripping, repair any issues, and then re-tighten them properly. Then, I would check for the issue once again. If the problem still exists I would start looking for a possible split in a line. You might also check for any leaking coming from the underside of the booster, master cylinder, or equalizer valve. I guess that would be a good start. Once you have found it and fixed it I would completely bleed all of the brake lines until fresh clean fluid runs out all of the bleeder screws. Good luck and let us know how it turns out.
Old 09-25-2012, 09:34 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
I don't have that problem. But, I have developed a method of finding leaks on things prone to having fluid run down and get on everything: Clean things completely with brake cleaner and then wrap the suspected part with blue paper shop towels and secure with tape. Check frequently during/after use. I usually can find the leak pretty quickly that way as the towel will get wet where the leak is and, if checked frequently enough, that's the only place that's wet.
Old 09-25-2012, 10:07 AM
Grubbworm's Avatar
Quote:
That is a really good idea, I may have to try it sometime.
Old 09-25-2012, 07:02 PM
The problem appears to be where the brake lines split front to back. The reservoir for the back brakes drops really quickly but the one for the front doesn't at all. I'm going to try and replace the connection I guess? I'll probably try the blue towel thing, then hunt more parts cry a bit and hopefully it works. If it doesn't I'll probably set it on fire. I'll update again in a few hours.
Old 09-25-2012, 07:29 PM
Gary Lewis's Avatar
Good luck! Stay away from the fire idea. Lots of us would love to have the parts.
Old 09-25-2012, 08:21 PM
The problem is that pressure/regulator valve thing. Probably, anyway I've got the towel in it and I have to hunt one down for my mechanic. Any suggestions on where to get one? I'm not going to a junkyard fyi. I'll probably try Lordco. My mechanic says it's something like 1-200 bucks to do my pressure valve thing and another 5-600 for tie rods the drag link and an alignment. What does everybody think about those prices.
Old 09-25-2012, 08:41 PM
Gary Lewis's Avatar
I think paying 100 to 200 for the proportioning valve when you could get one from a salvage for ~$5 is way steep. What do you have against salvages?
Old 09-25-2012, 08:46 PM
The 1-200 comes from the labour involved in redoing all the lines surrounding the valve. There are no trucks of this generation in junkyards around here. I called 6 junkyards and there's only one truck with different brakes than mine with huge rust. I prefer new parts anyway, well that's not true, I prefer not having to fix **** but, oh well. The price seems reasonable to me, all labour for taking rusty, ****ty things apart. Nothing has been easy on this truck.
Old 09-25-2012, 09:16 PM
Gary Lewis's Avatar
Quote:
Works for me if it works for you. Didn't realize you don't have any of these trucks in the salvage up there. Good luck.
Old 09-25-2012, 11:56 PM
john59923 john59923 is offline
john59923 is starting off with a positive reputation.
Okay, the valve on the frame is the Proportioning valve and mine is not working well and is leaking also. There are plenty of spare(i.e., used) parts in this neck of the woods, but like you, I don't trust used parts when it comes to the brakes(bad brakes could kill someone). The valve is easy to replace. There are only five lines to loosen and two bolts that hold it to the bracket. The problem comes in when bleeding. The bottom of the valve also needs to be bled(the spring portion at the bottom of the valve doesn't bleed well). It takes a 3/4 box end wrench to loosen.
You MUST have clear new fluid flowing solid(no bubbles) flowing from it in order to ensure that the valve has bled properly. Then, bled the brakes normally.
A footnote: if the new master cylinder has not been bench bled properly it will not work(spongy pedal, soft brakes) properly.
Old 09-26-2012, 12:30 AM
Yeah I'm pretty sure the master was done right because when i top up my brake fluid I can lock up all four wheels. Very quickly after that it doesn't work anymore. To be quite honest I think one of the lines might be split as well and I don't really have the time/ knowledge/ tools to be screwing around with my daily drivers brakes. I feel way more comfortable painting something than pulling on my rusty brake lines. The truck is rusty . . .
Old 09-26-2012, 12:37 AM
I hate rusty stuff--makes things way more difficult....
Make sure it is not a line that has rusted through....
Like my rear fuel tank, and I missed the part about the line in your reply
Old 10-03-2012, 01:22 AM
The problem was the proportioning valve part of the brake metering valve/proportioning valve assembly. There are no assemblies around here only one truck I found within 100 miles. Also Ford doesn't have the part either.Anyway the universal proportioning valve was 70 bucks and my mechanic charged me 100 bucks to plug up the broken assembly and route the line through the new proportioning valve. The light on my dash which tells you when you lose brake line pressure doesn't work anymore as a result of the ghetto fix. It never worked but anyway this is how my problem was resolved. Also I tried the blue towel thing, I went to the grocery store and back home and the towel was absolutely soaked, like less than 5% of it was dry lol.
Question about a blown brake line and pedal to floor artfd 1997 - 2003 F150 10 05-16-2015 09:11 AM
Rear brake line leaking sundancer330 1999 to 2016 Super Duty 3 10-09-2010 10:15 PM
2000 F350 front to rear brake line w.a.nelson Brakes, Steering, Suspension, Tires, & Wheels 6 10-27-2008 04:07 AM
94 F150 2WD Front Driver side Brake Line Leak robin22m 1987 - 1996 F150 & Larger F-Series Trucks 3 11-27-2006 09:47 PM
Air in the brake system restorit 1978 - 1996 Big Bronco 17 03-27-2002 12:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
