4 wheel drive hop - Ford Truck Enthusiasts Forums
4 wheel drive hop
Old 09-25-2012, 12:32 AM
clear1987 clear1987 is offline
clear1987 is starting off with a positive reputation.
4 wheel drive hop
Okay, the other day i had to use the 4 wheel drive on my 1987 ford 150. i put it in 4H knowing thats all i needed to get out but when i tried to go it ground and then hopped. the 4L worked just fine but when i drove it in 4L i could hear a clicking coming from what sounded like the front drivers side drive shaft. Does anyone have a guess to what the problem could be?
Old 09-25-2012, 03:35 AM
Opossum Opossum is offline
Opossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to allOpossum is a name known to all
If your going in a strait line you need to make sure your ratios are the same front to back. Turning it's normal for it to hop and the clicking could be the hub.
Old 09-25-2012, 07:09 AM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
Sounds like that clicking you hear is a bad joint. Lock in that hub and twist the inner shaft to check for any play
Old 09-25-2012, 10:49 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
You didn't say where you were driving it in 4wd but just so you know the truck should not be locked in 4wd Hi or Low on pavement or even hard packed dirt unless you're only travelling a short distance straight forwards or backwords. Turning while in 4wd on those surfaces will put extreme stress on the drivetrain and could very well damage components.
Old 09-25-2012, 11:09 AM
bobsf-350 bobsf-350 is offline
bobsf-350 is starting off with a positive reputation.
Sounds like a lock out hub could be the problem also if its not a u joint
Old 09-25-2012, 12:19 PM
dixie460's Avatar
dixie460 dixie460 is offline
dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.dixie460 has a good reputation on FTE.
+1 on a lockout hub. If it sounds like the axle, it's probably the hub. Auto hubs were one of Ford's "better" ideas lol... as soon as I get back on my feet money-wise, I'll be replacing mine with manual hubs.
Another possibility is your transfer case ate a shift fork. Mine did when the oil pump let go, and it trashed the shift forks so the transfer case wouldn't completely engage in 4H/4L. 2H worked fine for a while, no noise whatsoever but it would randomly go to neutral for a second and make a quiet ratcheting noise... then back to normal like nothing ever happened. Rebuilt a manual shift model, swapped it in, and been happy ever since.
I don't think transfer case is your problem though, mine made a grinding sound directly under the cab, unmistakable that it was trying to say HEY I'M YOUR TRANSFER CASE AND I WANTED YOU TO KNOW I'M AFU!!
Old 09-25-2012, 10:57 PM
I never use 4wd on pavement or even gravel, i was in mud when i was using 4wd. the clicking isn't what im really concerned with but i wanna know why it grinds in 4h. i can shift into gear but when i let off the clutch it grinds until it finally pops into 4wd.
hop hop!!!!!!! brokeisnojoke 1994.5 - 1997 7.3L Power Stroke Diesel 7 06-29-2011 11:29 AM
4x4 help spudgunman 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-24-2010 08:10 PM
Rear End Shake/Hop when hitting Brakes @ 45mph Firminator_X 1997 - 2003 F150 16 02-14-2009 05:52 PM
Explorer Shudders when Turning in 4wheel Drive Bergj1 Explorer, Sport Trac, Mountaineer & Aviator 3 12-30-2004 09:07 PM
wheel hop?? umdstang 1997 - 2003 F150 13 10-10-2003 12:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
