Better gas mileage in 2004 F-250 Powerstroke - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-24-2012, 11:18 PM
highcountry4 highcountry4 is offline
highcountry4 is starting off with a positive reputation.
What Can i do to get better then 8mpg? I drive a 2004 f-250 powerstroke that is lifted 6 inches with 38' inch tires. It has an edge performance tuner. Is that good? Should i put a bully dog in it? Anything else that i can do in order to get better mpg other than droping it.. Thanx
Old 09-24-2012, 11:19 PM
I am averaging 8mpg right now
Old 09-25-2012, 07:00 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Your lift and tires are the first reason. The lift causes more aerodynamic drag. The 38 inch tires cause more rolling resistance.
As for the tuner, I can't say one way pr the other.
A big factor in mileage is your driving. Power Stroke owners report good mileage gains by taking it easy on the throttle and never letting the engine go above 2000 RPMs.
Old 09-25-2012, 10:06 AM
blueline970 blueline970 is offline
blueline970 is starting off with a positive reputation.
If you have an automatic trans need to trash the edge tuner. Hell on the trans. Might try looking into custom tunes for your truck though may only be able to squeze out about 1mpg. Post/search in the 6.0 forum and you will probably get more info.
Old 09-25-2012, 10:07 AM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
As long as your truck's description includes "6 inch lift and 38 inch tires" anything you do will be pissing into a headwind. More air resistance, more rolling resistance, literally everything you've done to the truck makes is less efficient. As for adding a tuner, if you can square making more power by burning more fuel as a way to decrease fuel consumption you're going to be a rich man.
Well, less rich if you run a Bully Dog. That new trans you're going to be buying will eat into any economy savings you manage to imagine that you're gaining. If you want to tune it run a custom tuned SCT or PHP Gryphon paired with PHP FICM tuning, and at least the truck will be more fun to drive while still getting 8mpgs.
Old 09-25-2012, 11:19 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
The only thing that can most effectively fix your mileage situation is gears...4.56 gears to be exact. You can't expect your truck to continue to get good fuel economy with bigger tires.
4.56 gears will put your truck back to 3.73 with your 38s. When I had 3.73 gears with my 35s, it caused a drag and I averaged 13-14 mpg even with a chip. After regearing to 4.10, I regularly average anywhere from 16-19 mpg even lifted.
Old 09-25-2012, 12:21 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
Regear 4.56 or 4.88
Old 09-25-2012, 08:39 PM
So my best option is to regear to 4.56 or 4.88 gears. With that 6" lift will I be looking at a few more miles per gallon or just a small amount? What will the gears do to everyday driving? I can afford the bully dog system. I jut don't know if it will help enough to make that worth it. Thanx everyone for the knowledge and input. Any more ideas are welcome
Old 09-25-2012, 09:02 PM
ktm101's Avatar
ktm101 ktm101 is offline
ktm101 is starting off with a positive reputation.
I am lifted 6 1/2"s running 37's and average 15mpg.. i am running 4:56 gears also to bring it back..dont let everyone fool you about the lift and tires..you just need to finish the job with some gears..
Old 09-25-2012, 09:13 PM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
With the Bully Dog start saving money for the new transmission you will
need it. Your better off with the STC and some tunes from Matt at Gearhead.
His tune does not eat transmissions and can help after you re-gear the truck.
Banks and the Dog bad news
Come over and visit and ask what people think
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Sean
6.0 Diesel getting 13.3 MPG..... HilllBillly Excursion - King of SUVs 14 03-27-2015 04:33 PM
v10 5-7 mpg??? ajmicek Modular V10 (6.8l) 30 10-10-2014 03:08 PM
FUEL MILEAGE 2006FordF250 6.0L Power Stroke Diesel 45 09-09-2014 02:37 AM
Mpg? Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 29 05-08-2014 11:09 AM
6.0 powerstroke 03 or 04 engine how can i tell?? curlb 6.0L Power Stroke Diesel 6 03-15-2004 05:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
