Here goes my build thread(97 f350 Frameswap)
So we got a donor frame. it came from a 1994 f350 reg cab long bed. plan is to put it under my great truck that has a bent frame. we picked it up this weekend in crawfordsville indiana, was a 3 hour drive each way for us but it was worth it, also got a perfect condition drivers side door for 75 bucks and the frame was 300. still need to get a front clip. so here is the begining to my frame swap: Enjoy!
today i took off what was still on it which was the wiring harness, fuel lines and brake lines and gearbox. started cleaning up the frame with a wirewheel today also but it got dark so i will take pictures tommorrow
Hop on board cause this build should be a goody
the frame is from a single wheel with a diesel. my truck is a single wheel with a 460. we have to change the motor mount plates out with the diesels and maybe a few other things but is supposed to work fine. mine is a 97 350. here is the link to the story behind why i'm doing this hahah
https://www.ford-trucks.com/forums/1...some-help.html
haha figured you would notice that, i know your really knowledgable around here. but as for wirewheelin its my only option. nobody my uncle knows has a blaster we could borrow and not gonna pay to have it done, its on my time anyways so i dont mind i have nothing to do until my por-15 gets here as it is
Sandblasting generally gives a better result. More even, less scoring of the metal and it can get into hard to reach places like corners, cracks, holes ect. better than a wire wheel. I would trust Brad on this one. All the trucks he rebuilds turn out flawless. Yes it will cost more, but you won't regret it in the end. Just my $0.02...
A mobile sandblaster can do your frame in about 2 hours and for about 2-300.
If you take it somewhere, it will take about an hour and should be between 100-200.
TRUST me, I have done the grinder with wire wheel thing, and then I discoverd sandblasting. I dont even pickup a grinder with wire wheel any more
NOTHING will get RID of rust nor give the metal the "bite" better than sandblasting
