Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 09-24-2012, 08:59 AM
SuperDutySoldier SuperDutySoldier is offline
Garage is empty, add now
SuperDutySoldier is starting off with a positive reputation.
Long term storage reccomendations?
I am going to be moving to Europe for about 3 years, and will not be taking my F250. It is going to be stored in a covered space. It will be in the cold winters of upstate new york, and I have family members that will drive it occasionally to keep the moving parts from freezing. Just wondering if anyone has any experience with storing a 6.2L for a long period of time. Any stabilizer reccomendations or suggestions would be helpful. Thanks
  #2 (permalink)
Old 09-24-2012, 02:02 PM
Beechkid Beechkid is offline
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
SDS...our family has a long history (40+ years) of storing vehicles (toys) for both short & long term durations..here is my recommendation for long term storage...
1. Once parked, don't drive it.....periodic operation can induce more problems than if you let-it-be in most cases.
2. Wash, wax it, completely clean the interior and place an open box on a tray on the floor of baking soda.....it will help absorb moisture
3. Tires.....today's tires will not get flat spots like those built befor 2000......overfill them by 10 psi and this will help to ensure roundness.....if you want to fill them with nitrogen, this is ok as well because it is no prone to temp changes, precludes moisture formation & dosen't leak (larger molecules). If exposed to sun, place large trashbags (contractor type) over theem to protect against UV light.
4. Fuel- add fuel stabilizer (I like Marvel Mystery Oil) and fill tank to the top......fuel will begin to "turn" to a varnish like substance beginning at 6 months, with enough fuel stabilizer, this will prevent that. Filling to the top will eliminate as much air in the tank as possible which is a requirement for condensation & "turning" of the gasoline...this helps to stop it. I personally don't like to drain a system because especially using the MMO, it lubricates the "moving parts", which although it still sometimes happens, will help prevent hardening of o-rings, gaskets, injectors, etc.
5. ensure all fluids are topped off, lube/grease everything including graphite in all locks, dry lube in the window seals, etc. Don't bother changing fluids, etc...you will want to do this befor you fire it up upon your return. I would recommend purchasing a radiator anode (zinc) from JC Whitney...they sell for about $10, place it in the raditor overflow...it will act as a sacrfical lamb for the entire cooling system- keeping it corrosion free.
6. Pull the battery.....on a short term, disconnecting the terminals is ok, long term, pull it just in case....especially with temp changes, although very rare, a crack in a battery case undetected can do a lot of damage.
7. Place a plastic bag over the end of the air intake tube or filter...this will help keep bugs/dirt out.
8. If there is a potential for rodents, place a few moth ***** in the engine compartment.....if the storage facility has cats, forget it...the cats will do the work.
When its time to start it for the 1st time, check all the fluids, change the oil (this will provide some lube from the top down in the engine) spin the engine over for 30 seconds...it may or may not start- its ok....wait 1 minute, repeat......the 1 minute is a good cooldown for the starter and the 30 second duration will not overly stress any component. By the 2nd or 3rd round, it should start...probably run a little rough, but it will be ok. After 50 miles of driving time, drain all the fluids & replace (coolant may be ok), but definitely engine, tranny, power steering, brake.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #3 (permalink)
Old 10-08-2012, 06:47 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Just want to add...leave a list of what was done or needs to be done on the steering wheel or dash so that upon your return you will know.
Also if you have GEICO or USAA be sure to tell them what you are doing so your rates will go way down during this period.
Thanks for your service and enjof FRG. Go see some castles.
__________________
http://www.ford-trucks.com/forums/pi...ctureid=114550
Scott-2008 F250 PSD Crew Cab 4x4, 12K GVWR,
Cooper Discovery STT LT275/70R18's
Banks Ram Air & 6-Gun, Ravelco Alarm System, Frontier Extreme FT. Bumper
2013 40' 4-slider stoneridge 5th wheel coming in at 15,400
http://www.ford-trucks.com/guidelines.html
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
