engine miss and kill when warm. p1280, p1211 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-24-2012, 01:23 AM
cyco cyco is offline
cyco is starting off with a positive reputation.
Engine misses or kills when warm. p1280, 1211
<HR style="WIDOWS: 2; TEXT-TRANSFORM: none; BACKGROUND-COLOR: rgb(209,209,225); TEXT-INDENT: 0px; LETTER-SPACING: normal; FONT: 13px verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; WHITE-SPACE: normal; ORPHANS: 2; COLOR: rgb(209,209,225); WORD-SPACING: 0px; -webkit-text-size-adjust: auto; -webkit-text-stroke-width: 0px" SIZE=1>I started with an occasional miss which would kill the truck after it had been idling a few minutes. No engine light would flash and the truck would start right up. This happened maybe three times over a month. The engine always cranks quickly. Then the engine died suddenly while driving. Again no engine light. The truck would not fire at all when cranking. After it cooled for an hour waiting for a tow it cranked right up. After towing home, it would still crank and run for a while fine when cold but it may miss a few times then eventually kill and not restart after warmed up. The <ACRONYM title="Injection Control Pressure">icp</ACRONYM> did have slight oil in the plug. I tried disconnecting the <ACRONYM title="Injection Control Pressure">icp</ACRONYM> when it killed and it still would not restart. Once the engine cooled it would run again. Up to this time I did not have any engine light. I did have p1280 <ACRONYM title="Injection Control Pressure">icp</ACRONYM> low and p0340 cam sensor. Both of these would clear and not return until the engine missed or died again. (Typically 5-10 min once it heated up)
I replaced the cam sensor. No change. The same problem as above except P0340 did not return.
I again tried unplugging the <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> but did not find it made a difference when the engine died. I also tried cleaning the <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM> and <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> plugs. Still no change.
I replaced the <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM> with a new <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM>. Now the engine light stays on. P1280 stays on with key on engine off and will not reset. After the engine runs a few seconds the <ACRONYM title="Injection Pressure out of range, above or below desired">P1211</ACRONYM> (<ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM>not controlling) will also set. The engine will start missing once it warms up again.
I tired wiggling the wires to the <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM> and the engine would not miss. I also deep cleaned the <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM> plug as it looked like it had never-seize compound and dirt on the wire side. The rubber seal which stayed with the old <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM> was also broken and may have had heat damage. Even though the <ACRONYM title="Injection Control Pressure">ICP</ACRONYM> had a slight leak, I thought it was ruled out with the unplug test. I also replaced the oil and oil filter.
Iím worried because the problem is getting worse as if new <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM> or plug is bad. My next thought is to go to international and get an <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM> pigtail and maybe also replace the <ACRONYM title="Injection Control Pressure">ICP</ACRONYM>. Is this correct? Any other thoughts?
2002 f350 stock 7.3 210k miles
Old 09-24-2012, 01:49 AM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Quote:
Originally Posted by cyco View Post
..... My next thought is to go to international and get an <ACRONYM title="Injection Pressure Regulator">IPR</ACRONYM> pigtail ...
That would be my next step as well. If you happen to have an old Under Valve Cover Injector harness you can source a pigtail that way....(the injector connector is the same as the IPR and EBPV solenoid connectors).
I have been seeing more and more issues with the IPR wiring harness lately....maybe they have reached their maturity and are just now starting to fail.
Old 09-24-2012, 10:22 AM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Riffraffdiesel has both those parts and might be alot cheaper.
Old 09-24-2012, 10:53 AM
DP-Tuner's Avatar
DP-Tuner DP-Tuner is offline
PREMIUM SPONSOR
DP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to beholdDP-Tuner is a splendid one to behold
<hr style="WIDOWS: 2; TEXT-TRANSFORM: none; BACKGROUND-COLOR: rgb(209,209,225); TEXT-INDENT: 0px; LETTER-SPACING: normal; FONT: 13px verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; WHITE-SPACE: normal; ORPHANS: 2; COLOR: rgb(209,209,225); WORD-SPACING: 0px; -webkit-text-size-adjust: auto; -webkit-text-stroke-width: 0px" size="1">I started with an occasional miss which would kill the truck after it had been idling a few minutes. No engine light would flash and the truck would start right up. This happened maybe three times over a month. The engine always cranks quickly. Then the engine died suddenly while driving. Again no engine light. The truck would not fire at all when cranking. After it cooled for an hour waiting for a tow it cranked right up. After towing home, it would still crank and run for a while fine when cold but it may miss a few times then eventually kill and not restart after warmed up. The <acronym title="Injection Control Pressure">icp</acronym> did have slight oil in the plug. I tried disconnecting the <acronym title="Injection Control Pressure">icp</acronym> when it killed and it still would not restart. Once the engine cooled it would run again. Up to this time I did not have any engine light. I did have p1280 <acronym title="Injection Control Pressure">icp</acronym> low and p0340 cam sensor. Both of these would clear and not return until the engine missed or died again. (Typically 5-10 min once it heated up)
I again tried unplugging the <acronym title="Injection Control Pressure">ICP</acronym> but did not find it made a difference when the engine died. I also tried cleaning the <acronym title="Injection Pressure Regulator">IPR</acronym> and <acronym title="Injection Control Pressure">ICP</acronym> plugs. Still no change.
I replaced the <acronym title="Injection Pressure Regulator">IPR</acronym> with a new <acronym title="Injection Pressure Regulator">IPR</acronym>. Now the engine light stays on. P1280 stays on with key on engine off and will not reset. After the engine runs a few seconds the <acronym title="Injection Pressure out of range, above or below desired">P1211</acronym> (<acronym title="Injection Pressure Regulator">IPR</acronym>not controlling) will also set. The engine will start missing once it warms up again.
I tired wiggling the wires to the <acronym title="Injection Pressure Regulator">IPR</acronym> and the engine would not miss. I also deep cleaned the <acronym title="Injection Pressure Regulator">IPR</acronym> plug as it looked like it had never-seize compound and dirt on the wire side. The rubber seal which stayed with the old <acronym title="Injection Pressure Regulator">IPR</acronym> was also broken and may have had heat damage. Even though the <acronym title="Injection Control Pressure">ICP</acronym> had a slight leak, I thought it was ruled out with the unplug test. I also replaced the oil and oil filter.
Iím worried because the problem is getting worse as if new <acronym title="Injection Pressure Regulator">IPR</acronym> or plug is bad. My next thought is to go to international and get an <acronym title="Injection Pressure Regulator">IPR</acronym> pigtail and maybe also replace the <acronym title="Injection Control Pressure">ICP</acronym>. Is this correct? Any other thoughts?
What is the part number for CPS you installed? Color of the CPS?
__________________
Jody & Diane Tipton- DP-Tunerģ
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l and 6.7l
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Runs great cold, horrible when hot. Zejokee 6.0L Power Stroke Diesel 17 05-19-2014 01:44 AM
1211 and 1212 codes countrycar 1999 - 2003 7.3L Power Stroke Diesel 8 11-21-2012 08:16 PM
Injector buzz test and some questions dyoung14 1994.5 - 1997 7.3L Power Stroke Diesel 10 01-22-2011 12:24 PM
EXTREMELY rough running after startup, but cleared up? WTF??? strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 27 04-03-2010 07:39 AM
knocking under load.... strokin'_tatsch 1994.5 - 1997 7.3L Power Stroke Diesel 96 03-03-2010 10:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
